Keypad/Handle Install Problem - Odd problem
Old Sep 29, 2001 | 10:13 PM
Silver_2000's Avatar
Lightbulb
Just did my keypad install and had to modify the handle.
I posted pictures of the process as an update to the great keypad install that you guys put together last year. Check out the How Tos on SVTLightnings.com for pictures of before and after the mod
Doug
Old Oct 8, 2001 | 07:21 PM
FlippinFord's Avatar
Keypad install
If anyone out their has done this to a 99 then i need your help , could you please contact me at twatkin3@columbus.rr.com, I did this install and almost everything worked except buttom 12 would not light the interior lights but buttons 34 56 78 90 would light the interior lights and i had no keypad illumination but i could still enter code and lock and unlock doors i figured a bad connection somewhere so i solder all the connections directly to the rap module then hooked everything back up now i can still push buttons 34 56 78 90 and the interior lights will come on but still no keypad light and now buttons 78 90 won't lock and the code won't unlock have checked all connections and used a meter, what could possibly be the problem the remotes still work to lock unlock and the panic button works but I have nothing but a interior light up on buttons 34 56 78 90 and absolutely continuty from the buttoms on keypad to the rap module and continuty thru the illumination on the keypad, could the rap module be bad or the keypad actuactor. HELP
