Racing Gas
Old Sep 21, 2001 | 01:29 PM
easterisland's Avatar
Question Racing Gas
Is $3.95 a fair price for Sonoco 104 unleaded? I have to buy a 55 gallon drum.
What type of mixture do I do? I was thinking about 4.5 gal of 104 to 5 gal 93 to equal 100octane. Is that pretty close?
Will it hurt the engine to run high octane w/o a chip?
Old Sep 21, 2001 | 01:40 PM
Spiro99SVT's Avatar
I just purchased 5 gallons of Sunoco GT 100 for tomorrow, and to my surprise it was still only 2.99 a gallon.
If anyone needs some, I could bring 5 gallons in my fuel Jug for tomorrow. Im running 5 gallons 100, and 6 93.
Old Sep 21, 2001 | 01:49 PM
I could only find one place here selling the GT 100. It was $4 a gallon! The 104 was only $3.95.
Old Sep 21, 2001 | 01:59 PM
DB's Avatar
DB
Be glad you don't live in CA.
The last time I bought 100 octane unleaded from 76 it was $4.59/gal.
Also, the best premium you can get is 91 octane now
Old Sep 21, 2001 | 02:09 PM
Spiro99SVT's Avatar
Thats way too much if you ask me. I know near the local track 100 octane sells for 4.50 a gallon.
Here's some info I found.
SUNOCO GTTM UNLEADED
For classics, street rods, muscle cars, motorcycles, exotics, and showroom stock racing. Sunoco GTTM Unleaded is a pacesetter. It has a comprehensive additive package for greater engine protection and cleanliness. And it’s unsurpassed for racing cars that require unleaded gasoline, and those with knock sensors, computers, or turbo-charged engines. GTTM Unleaded is formulated to meet OPRG standards for reformulated gasolines within all 50 states.
Fuel Property Typical Specifications
Specific Gravity 0.760
Pump Octane (R+M)/2 100
Reid Vapor Pressure 8
Distillation,°F
Initial Boiling Pt. 90
10% Evap. 150
50% Evap. 210
90% Evap. 230
Final Boiling Pt. 260
Color Clear
SUNOCO GT PLUSTM UNLEADED
Sunoco’s newest high performance unleaded racing fuel. Created for race cars, bikes, and boats with compression ratios up to 14:1, GT PlusTM is designed with the professional racer in mind, and should not be used on the street.
Specific Gravity 0.735
Pump Octane (R+M)/2 104
Reid Vapor Pressure 9
Distillation,°F
Initial Boiling Pt. 100
10% Evap. 135
50% Evap. 200
90% Evap. 230
Final Boiling Pt. 255
Color Lt. Blue
Old Sep 21, 2001 | 02:10 PM
Jay Lincoln's Avatar
Unless you have a detonation problem with your existing set-up, or plan on running with an enhanced chip, racing gas may slow you down. Let me explain.
Generally, racing gasoline is formulated to burn slower, to combat detonation. My son went racing at the street legal drags a while back, and put unleaded racing gas in his blown Chevelle. He did not bump up the timing, or increase the boost, and immediately slowed down.
If you have a detonation problem, racing gas will alleviate this, and you may run better, but you will definitely be safer. If not, you will need to increase the timing, and possibly lean down the mixture as well.
The tuners here should be able to set you in the right direction.
Old Sep 21, 2001 | 02:15 PM
Well, I should have my JL racing Diablo chip next week(just in time for B.G. NMRA ) along with that 4# pulley and was under the impression I should run 100 octane. I just really had no idea how I should mix the 104 with 93 to get the best results. I also wanted to make sure that too much octane wasn't going to hurt the engine if I wasn't 100% accurate with my mixing.
I haven't had any pinging problems up to now and I only use Sams club 93 octane.
Old Sep 21, 2001 | 03:19 PM
liquidlightning's Avatar
Angry
be happy you only pay 4.00 a gallon here in ct.
for cam 2 where paying close to 6.25 a gallon.
and i run that everytime i fill it i do half 93 and half 104
just think how much money icould save if i would just ride
bike with pedals lol see you guys
Old Sep 21, 2001 | 03:27 PM
I thought that cam2 was Sonoco GT 100 or 100 octane and the GT plus was the 104 octane.
http://www.racegas.com/Racegas/fuelspecs/default.asp
Old Sep 21, 2001 | 03:29 PM
jrm1493's Avatar
why dont yall use airplane gas, it's 100 octane and it should be around $2-$2.50 a gallon. the only problem is that its leaded, but that will just screw up your cats and i'm sure some of yall have removed them anyway....
Old Sep 21, 2001 | 03:40 PM
noelvm's Avatar
JRM you know not of what you speak. There are four down line sensors in the L exhaust. Two before the cats and two after. The truck won't run right if you remove the cats. Second the leaded gas will fry the four sensors and then your truck will really run like *****.
104 is $5.25/gal here in Houston in 5 gal. lots. It's a little cheaper by the drum. I usually mix it 50-50 to get about 98 octane which is sufficient to run fine on all the chips I have. The biggest difference I have noticed with the 104 mix is the truck leaves harder and faster which helps with both your RT and your 60'.
I use it every week. It will not hurt your truck and you will never need to get your injectors cleaned.
noelvm
When I did a search for the gas I came across the same question. Someone answered and said the low lead airplane fuel has twice the lead as leaded gasoline.
Old Sep 21, 2001 | 03:50 PM
scampismith's Avatar
Avgas 100LL does not have twice the lead as leaded gas. I have run small amounts of Avgas for years a little will not hurt but too much will ruin your cats and 02 sensors.
Old Sep 21, 2001 | 04:09 PM
usahooters's Avatar
Thumbs up octane
I haven't been able to help anyone on this sight only learn from you guys but maybe this time I can do some good. My good friend is a Blender at Chevron refinery. He blends anything from reg. unleaded to jet fuel. He will be able to tell us exactly what you want to know about mixing fuels. I'll see him tonight and post a good thread on it tomorrow.
Old Sep 21, 2001 | 04:20 PM
Ak.Silver2K's Avatar
Freight?
Sunoco 104 is $6.50 a gallon here in Alaska, and the only place I've found it so far is a Texaco station in Anchorage.
Glad I don't need much.
Mark
