check engine soon
Old Sep 13, 2001 | 02:29 AM
'00WhiteLightneeen's Avatar
Question check engine soon
Guys, if I disconnect the battery, should that clear the "check engine soon" light (assuming the problem is fixed)? I put my stock air system back on tonight to send the chip in for a reburn but forgot to plug in the air temp sensor cable. Even after plugging it in, the light was still on.
Old Sep 13, 2001 | 02:57 AM
z96Cobra's Avatar
If you disconnect the battery for a few minutes, and assuming everything else is ok with the truck, the light should go out and stay out. You should only have to have it disconnected for a couple of minutes if that long.
Later,
Roger
Old Sep 13, 2001 | 04:43 AM
StrikesTwice's Avatar
Is it true, that to reset the computer, the battery must be disconnected for aprox. 10-12 hours?
Old Sep 13, 2001 | 06:21 AM
4D THNDR's Avatar
Lightbulb
Nope, disconnecting it for 5 mins or so should clear it. When you reconnect and turn on the key it goes through a self diagnostic where all the gauges (except boost) peg to the max then return to normal in 2-3 seconds. Also, your radio will also need to be reset.
Old Sep 13, 2001 | 12:45 PM
Thumbs up
Thanks guys, lights out now.
Noelvm, glad you didnt read this one earlier... I realized right after I sent it that I would probably get nailed with the "try the search" answer
Mike
Old Sep 13, 2001 | 01:24 PM
StealthL's Avatar
My 99 had the light on when I got it back in May. I took it to a dealer and they updated the computer. I have not had any more problems.
SV
Old Sep 13, 2001 | 05:46 PM
redlite's Avatar
StealthL, I had the same thing happen to me in July. To turn light off, the Dealer says they reprogrammed the computer. I did not really understand their explanation. They said Ford or SVT recommended it as an upgrade. Truck seems to run fine.
Old Sep 13, 2001 | 05:48 PM
redlite's Avatar
Forgot to mention that the check engine light came on at almost exactly at 15,000 miles.
Old Sep 13, 2001 | 10:45 PM
super dave's Avatar
Check and make sure you didn't bump a vacuum line loose when you were replacing your stock equipment.
Old Sep 13, 2001 | 11:33 PM
StealthL's Avatar
Redlite,
yeh I think the guy I bought mine from knocked the pcv out and ran it a while before he noticed it. I don't know if that had anything to do with it or not.
SV
Old Sep 14, 2001 | 07:45 AM
LIGHTNINROD's Avatar
Mike Troyer.........
Superchips dist.(in Computer Chip) recommends to remove the neg. cable, turn the headlight's switch 'on' for 5 mins. or longer(suppose to remove all 'residual' voltage from the ECU), and then--turn the h/l's OFF before reconnecting the neg. cable.
The above is what I remember(not quoting Mike word-for-word) and it is what I do when changing the chip or making other mod changes.
Dan
