Shift kit install question
Old Sep 6, 2001 | 05:07 PM
EvilGuy's Avatar
I just recieved my LFP line mod and 4x4 pan and have some questions about the install. Which end of the truck should I jack up? and the torque specs for the valve body is 80in. lb and the pan is 15?
Old Sep 6, 2001 | 05:40 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
side to jack up? I say front.
valve body is 80 in/lbs
pan is 15 - 20 FT/lbs.
gasket is reuseable.
No 4x4 pan and filter?
Start at the right rear corner and alternate side to side from the corner bolt until you reach the left front corner.
oh yeah, buy a bag o kitty litter, a large catch pan, and lint free rags to handle the valve body. It's gonna be messy.
Old Sep 6, 2001 | 07:55 PM
EvilGuy's Avatar
Thank you Bob, one more question. I need 7 quarts of trans fluid right?
Old Sep 6, 2001 | 08:08 PM
DB's Avatar
DB
Yep 7 quarts will do it with the 4X4 pan.
captainoblivious's Avatar
a couple people who replace the tranny pans just punch a hole in the factory one and let the fluid drain out before removing the whole pan.
Old Sep 6, 2001 | 08:10 PM
Arrow
I recall using 5.5 qts. but I had liberty of using a lift. (THANKS AGAIN OLEFAFL)
With your truck being on an angle, you may have to add a bit more fluid.
Start with 4 qts, start it up, let it warm up, go from R to D and back a few times, put it in Neutral, leave it running, check the 'stick, add where necessary, repeat from R to D. Drive it a couple days, check it again, top off where necessary.
Have FUN and be sure to report how the line mod works. Just be careful!
Old Sep 6, 2001 | 09:15 PM
EvilGuy's Avatar
Hey Bob, hate to pester you, but do you happen to remember the size of the pan bolts? and the valve body bolts are 10mm right?
Old Sep 6, 2001 | 09:29 PM
olefafl's Avatar
Lightbulb
I think they are 10mm.
BTW: Take the magnet out of the the factory pan and put it in the 4X4 pan. BEFORE you start installing the new pan.
Old Sep 6, 2001 | 09:37 PM
easterisland's Avatar
On that valve body there are two 10mm nuts and a lot of 8mm bolts. Unless I put the accumulator valve on the wrong piece.
Old Sep 6, 2001 | 10:04 PM
01SVT's Avatar
I just did the install the other night and The bolt size is 8mm for the valve body bolts and 10mm for the nuts on the studs and 10mm for the pan. with the 4x4 pan I ended up puting in 6qt of mercon to top it back off.
Old Sep 6, 2001 | 10:09 PM
EvilGuy's Avatar
01svt, did you torque the pan nuts down or just tighten?
Old Sep 6, 2001 | 10:38 PM
01SVT's Avatar
Evil,
I torked the valve body down to 90in/lbs and the pan to 15ft/lbs the recomended tork is 80-100 in/lbs on the valve body and 10-16 ft/lbs on the pan.
check out this site for more information its great!
http://www.powersurgeperformance.net...c&f=3&t=000011
Old Sep 6, 2001 | 10:59 PM
What Ole' said.
Thank goodness for a reuseable gasket...
Old Sep 7, 2001 | 01:37 AM
LTNBOLT's Avatar
Cool
I just had mine done last Thursday. I actually watched this done twice in a row. Fast1Matt had his done first but didn't spring for the 4X4 pan. Ours were done on a lift by a Ford Tranny Tech so I would probably jack the front end up if I were doing it at home. I remember the 2 outside bolt being larger than the rest. The tech said to torque the valve body down in a random pattern like torqueing a head. He also said to not over tighten because it can warp the valve body. Matt's took 7 qts. of Mercon III with the stock pan. Mine took close to 8 qts. with the 4X4 pan. He checked it carefully several times while it was running. He made the comment that it was better for one to be under filled than over filled because of foaming or something to that effect. As many times as he checked and added to ours it must have been right on the money. He got me the the pan and filter at his cost. He only charged me $60 for everything. What a deal!!
