Soooooooo Close!!!!!!!!
Old Sep 2, 2001 | 03:28 PM
Jay Lincoln's Avatar
Thumbs up
Nice run Johnny! You are about 15 degrees in air temp or 100 lbs. from being in the 11's.
Old Sep 2, 2001 | 03:42 PM
JohnnyLightning's Avatar
thanx! or a .06 better 60 ft! = 11.96! which i plan on doing wed. night! Finger crossed. JL
Old Sep 2, 2001 | 03:50 PM
Does the track that you race at enforce the NHRA rules heavily? If you and a regular set of slicks, with a softer rubber compound it would definetely improve that 60 ft. time. The ET Streets need to have a harder compound to meet DOT specs.
Old Sep 2, 2001 | 05:11 PM
LIGHTNINROD's Avatar
Johnny:
Originally posted by JohnnyLightning
Thanx: but thats where i'm going to cut it off the 11.9 mark! JL
Man what a tuner and what a truck! Outstandin'!!!
Question: If you run 11s up north, you have to install a cage--right? I was told Fri. nite (while runnin' at Silver Dollar--remember when you were here?) that if--no, when I get to a 12, I've got to have a cage??? The guy said it was a NHRA rule??? Could this track have their own 'rules'?
Dan
Old Sep 2, 2001 | 05:16 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Thumbs up
Lyrics from this profound individual come to mind....
GO, GO Johnny GO, GO {insert cool guitar riff}
Old Sep 2, 2001 | 05:29 PM
Jay: Yes that's correct but the problem is i don't know of any company making a true slick with a softer compund in the 16" I don't want to go to the 15" rims because i want to beable to run 11's with just the easy bolt ons the avereage guy will do. i still have never been inside the engine never touched a bolt on the engine either. just bolt ons i sell are on the truck! even still have the same leaky intercooler
Dan: Are you the guy with the big Cigar? LOL! i believe unless the track has its own rules. you don't need a roll bar until you hit 11's! just a driveshaft loop if your in the 12's with slicks!
O speedy: As usaual you got me smiling! JL
Old Sep 2, 2001 | 05:54 PM
gforce's Avatar
Thumbs up
You're not excited at all, are you John? Way to go!!
Old Sep 2, 2001 | 05:57 PM
I Think i will be more excited if i ever lay my eyes on that 1st 11.? Time slip! JL
Old Sep 2, 2001 | 06:26 PM
RDY2RAC's Avatar
Thumbs up SMOKIN'
IF ONLY I COULD RUN HALF AS GOOD I WOULD BE HAPPY
SERIOUSLY THAT'S AWESOME, SO WOULD YOU RECOMMEND THE PLUGS? 1 ? WHAT'S WITH THAT .700 LIGHT
Old Sep 2, 2001 | 09:24 PM
99svtlightning's Avatar
JL: I definitely plan on being there Wed. night.
Old Sep 2, 2001 | 10:37 PM
Pantera's Avatar
Question
Cecil runs on Wed.?Cool! When do the gates open?Is it T&T only?
Old Sep 3, 2001 | 11:32 AM
Test and Tune is every other Wed. night, but I don't believe for much longer. Gates will open at 5pm.
http://www.cecilcountydragway.com
Old Sep 3, 2001 | 11:49 AM
L_Acious's Avatar
Thumbs up
WOW! Fantastic times Johnny. I look forward to seeing you and Sue in Bowling Green.
Frank
Old Sep 3, 2001 | 12:05 PM
Just looked on Cecil's website and the next Wed. test and tune is not until the 9th. Looks like Friday night is open.
Old Sep 7, 2001 | 05:27 PM
alphadoggy's Avatar
JL, I have had exactly the same kind of shifting problem that you describe ever since I put an aftermarket torque converter in my truck. It just blows by the 5500 rpm shift point and buries the tach at 6000. Then it activates the boost cut off and the truck doesn't go anywhere. I don't know how you can be running such great times unless you have disconnected the boost cut off. Sal seems to think that the problem lies with the discrepancy between turbing shaft speed and mph. https://www.f150online.com/forums/sh...threadid=48701 I assume that since you have the Precision Industries converter in your truck that the cause must be the same. Neither the Swanson chip or the JDM chip can solve this problem, although Sal thinks he may have a program that will. Evidently the Diablo chip is confused, too. I am sure interested in hearing from others with this shift problem, and whether they are able to cure it with a chip.
