1/4 mile times w/01 good or bad?
Well I finally made it over to the Route 66 strip. There was over 200 cars that nite. I was only able to make 2 passes. The elevation is 550'. Temp. was about 70 degrees. The track seemed to be hooking up pretty good. My only mods are the JDM filter kit and a Superchips flip. I have about 5,100 mile on her so far. My first run I launched from idle and pulled a 2.05 60ft. and ran a 13.56 @101.6. About a hr. and 1/2 later I made my second run. This time I launched from 1200 and still pulled a 60ft time of 2.05 but finished with a 13.45@102.2. Are these times weak, average, or slightly better than most? I am going back this Tues. to try it again. This is more addicting than crack! Any input would be appreciated. By the way that is full weight with an added driver wt of 200 lbs.
Did you lower the rear tires PSI?
I run about 25 lbs in mine and have gotten my 60 foot times down to about 1.8 If you can get them down to 1.8 your times will be in the 13.2 range.
So it shows you are running just fine.
