pillar gauges
Old Aug 19, 2001 | 08:02 PM
ally69's Avatar
pillar gauges
What other guages other than the boost gauge are people puting in there pillar pods that are usfull and easy to install.
Old Aug 19, 2001 | 09:11 PM
rscoleman's Avatar
I've got Auto Meter phantom boost, air/fuel, and nitrous press. gauges in a lo-tek full pillar pod. You can put volts in place of the nitrous gauge if you don't have n20.
BadAzz516's Avatar
Rest In Peace
Talking
I got Boost, Water temp, and Oil Pressure. The Boost is the easiest to install just T off of the line thats right under the dash from the stock guage. The Oil Pressure guage im not certian how that was done my buddie installed them for me think that he got brass fittings and T- somewhere of the stock sending unit. Then the Water Temp. guage wasnt to bad the sending unit for that fit perfectly into the drain for the block right in front of tranny and that is an accurate reading to if you read some post on installing the guages you will see some people tapped into the block and they said they werent getting an accurate reading but i do. Just remeber to have plenty of teflon tape if you do the 2 guages i that i did with my boost guage.
Vin
Old Aug 19, 2001 | 09:20 PM
noelvm's Avatar
LOL. That's an oximoron. Boost gage and useful don't belong in the same sentence. Add a volt meter which your truck does not have.
noelvm
