Lower pulley torque value?
Old Jul 31, 2001 | 08:32 PM
JeffsLightning's Avatar
Does anyone know what the torque amount is on the lower stock blower pulley bolt. It's the allen bolt that holds the pulley/cage to the crank. Thanks Jeff
Old Jul 31, 2001 | 08:46 PM
LIGHTNINROD's Avatar
Don't know...
but it's a bunch! I couldn't break it loose when changing to a PSP pulley so a friend had to do it for me. Must be 150+?
Dan
Old Jul 31, 2001 | 10:48 PM
Jay Lincoln's Avatar
According to my Ford Manual, it's a four step process. This indicates a torque to yield bolt. Are you using a new bolt?
My Ford manual says the following for the crankshaft pulley.
Step 1: torque to 66 lbs.
Step 2: Loosen 360 degrees
Step 3: Torque to 35-39 lbs
Step 4: tighten another 85-90 degrees
It also says under the Lightning section "tighten auxillary crankshaft pulley to 75 lbs".
It doesn't specifically call the aux. pulley the blower drive pulley.
I believe you must follow the first proceedure if you remove the large center bolt that holds the pulley(s) on the crank.
Hope this helps.
Old Jul 31, 2001 | 10:59 PM
LTNBOLT's Avatar
Question
Jay,
If it's a torque to yield bolt aren't you suppose to not reuse them?
I'm not sure.
Old Jul 31, 2001 | 11:52 PM
That is correct. Do not reuse torque to yield bolts. They will not read correctly.
