Hotchkis Help
Old Jul 20, 2001 | 09:09 PM
Silver-Bolt's Avatar
Question Hotchkis Help
Just ordered the Hotchkis suspension and would like input from anyone that has already installed it. Any tips , tricks, or things to watchout for? Are you happy with it?
The front and rear sway bars will be ready within 10 days. They have started a list for anyone interested. If you are call Hotchkis and ask for JD. He will take care of you.
The front bar is 1.5" and the rear is 1.0". Both are tubular. $535.00 complete with all hardware. The bushings are urethane.
The springs are rated at: 850LBS front and 220LBS rear.
Hotchkis no longer has cam bolt kits. Anyone know where I can get them. Part numbers? Thanks.
Old Jul 20, 2001 | 10:05 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Silver Bolt,
NAPA Part number...
$33.00 vs Ford's $100.00
Old Jul 20, 2001 | 10:48 PM
MadMaxSC's Avatar
Talking Aug. 31st
mine comes from Summit on 8/31. Thanks for the current info on the bars. I will order them too. I am doing this before any more speed mods. Of course, all I have is the 80MM, Babolt throttle body and the high flow air filter....but i will soon be in MOD HEAVEN
Old Jul 20, 2001 | 11:30 PM
DreaminAboutL's Avatar
Question
Hmmmmm... they told Spike the spring rates were 800lbs and 300lbs
Old Jul 21, 2001 | 12:25 AM
NOSTROMO
Guest
Posts: n/a
Cool the sway bars are finally here. Now i just have to instal the rest of my parts!
Old Jul 21, 2001 | 01:41 AM
MadMaxSC's Avatar
Thumbs down what the hell???
damn! I will call them Monday! If we get enough different numbers we can just average them like bowling ...bejeeeezuz....I want accurate info....maybe ruslow has a spring compression meter we would know for sure then!
Old Jul 21, 2001 | 01:56 AM
HANKFAN's Avatar
I have the rear Hotchkis leafs and they have been great. Seems to have helped with my axle wrap. At least while not running the nitrous anyways!
Old Jul 21, 2001 | 10:58 AM
The spring rates came from JD at Hotchkis. Not sure which is correct. I will check with engineering on Monday.
Old Jul 23, 2001 | 08:05 PM
Thanks to Speedin advise I went to NAPA and picked up the cam bolt kits. $13.85, I was like WTF?? He showed it to me same p/n so I bought 2 of them just in case. Also picked up the NGK 4177 for $1.97/ea. Cheap.
Old Jul 24, 2001 | 09:19 AM
NeedFourSpeed's Avatar
Now all we need is some shocks tuned for this setup.
Old Jul 24, 2001 | 09:27 AM
NeedFor,
I am going to try the 01 Bilstiens first. I am sure they will be an improvement over the stock 00 shocks. If the don't perform upto expectations I will opt for the adjustable Koni's.
Old Jul 24, 2001 | 03:28 PM
Hotchkis corrected spring rates.
Front = 850 lb
Rear = 300 lb
Anyone know what the factory springs are rated at?
Old Jul 24, 2001 | 08:37 PM
Spike Engineering's Avatar
Interesting spring rate data...
I just received an email from Hotchkis. Here's a shortened version:
...The springs you have are 960 lbs/in in the front and 300 lbs/in in the rear. It looks like JD accidentally quoted ... the dakota spring rate on the leaf
springs.
The sway bars are being sent to powdercoat tomorrow. We should see them late this week and on Monday we are taking installation photos and the kits should be ready for shipping at the end of the week (approx Aug 3rd). The sway Bars are going to be 1.5" OD hollow on the front, and 1" hollow on the rear.
Right now, the tuned shocks are several months away. ... the 2001 lightning shocks aren't bad. They are a Bilstein shock. We are planning to tune them in the next month or two.
-Gary Pinkley
via Spike
I guess the fronts spring rates are now in question
Regarding the factory spring rates, here they are:
650 lb. (front) - 200 lb. (rear)
http://media.ford.com/products/press...section_id=422 (see http://nloc.org/ubb/Forum2/HTML/000669.html)
BTW, I've been talking with Koni about tuned shocks. Maybe a little competition for Bilstein would be beneficial. Stan, are your shocks Koni's?
Spike
Old Jul 24, 2001 | 09:22 PM
MadMaxSC's Avatar
Unhappy
ladies and gentleman......its bowlin' for dollars...with Chick Hearn....
Old Jul 24, 2001 | 10:40 PM
I talked to the guys at http://www.shox.com
Supposedly Koni and Tokico both have adjustable shocks for our trucks.
I still plan to try the Bilstiens first. The price is too cheap not too. If not happy then the Koni's sound the most promising. Absolute best choicr is the Penske's. One small problem $750-$900 each. Ouch!.
