mandrel bent pipe???
Old Jul 20, 2001 | 04:56 PM
red2k#1554's Avatar
I just ordered a 14468 (the shorter) Magnaflow muffler for my 00L. Just wondering if anyone that has this muffler used mandrel bent pipe from the rear of the muffler to the stock tips and if so where did you buy it??? I see places selling them, but I have no idea what length or bend to get to reduce the work at the muffler shop when I get it installed.
Thanks,
Old Jul 20, 2001 | 05:39 PM
01 BLACK BOLT's Avatar
Registered User
Thumbs up
Hey Jim: Do you plan to cut and bend the new tail-pipes yourself, assuming you have the equipment?
I had the short 12468 installed at the muffler shop and they cut and mandrel bent new pipes to match the old ones and reinstalled my factory tips. I have no idea of sizes other than 2 1/2 pipe from muffler to tips.---Jim
Old Jul 20, 2001 | 05:54 PM
red2k#1554's Avatar
I plan on having it done at a shop but NO ONE here has a mandrel bender so I was thinking of buying two pieces and taking them it and letting them just bend it slightly to get to the right dimensions
Old Jul 20, 2001 | 06:54 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Jim,
When I had my magnaflow 12468 installed, the shop didn't have a mandrel bender (DOH) but the tech was not the run of the mill Goober so he used a dual-out conversion kit from a 97+ F-150.
He had to work the connectors a bit but it turned out OK considering. I'm satisfied.
Here's a photo, more in my gallery linked below. Hope this helps.
Old Jul 20, 2001 | 07:21 PM
01SVT's Avatar
I had my local muffler guy order and install my maganflow 12468 he mandrel bent new pipes between the muffler and the tips for $116.00 including the muffler!
Old Jul 20, 2001 | 07:32 PM
Mondo1's Avatar
All of Bassani's pipes and kits are mandrel bent tubing.They may sell you just the pipes ,I'm sure. A mandrel bending machine runs in the tens of thousands and mostley the bigger manufacturers have them.Go to their website.www.bassani.com
Old Jul 20, 2001 | 07:52 PM
trabuco's Avatar
Of all the ways to save a buck - this isn't one. Muffler work is relatively cheap and you'll get your money's worth...
