installed superchip....now lightning does not start.
Old Jul 15, 2001 | 06:20 PM
Dean_Anderson's Avatar
Unhappy installed superchip....now lightning does not start.
OMG!! just installed a superchip in my 2001 lightning. now it will not start. just cranks and cranks.
anyone have any ideas?
i am concerned about continuously attempting to start the truck if this is damaging something. (computer?)
i thought i read somewhere that it takes a couple extra rpms to start the motor after a computer reset.
also, i have also read that simply disconnecting the negative cable on the battery does NOT fully reset the computer. does anyone know the additional steps in fully reseting the computer?
thanks all in advance!
Old Jul 15, 2001 | 06:22 PM
Silver_2000's Avatar
Dean
RECLEAN the contacts on the PCM. Bet a case of beer that you missed one.
You may have seen this but here are pictures I took when I took mine apart. http://www.svtlightnings.com/svt/chip/chip.htm
As fast Gator said It goes back together easy
Doug
Old Jul 15, 2001 | 06:26 PM
Fast Gator's Avatar
I'll bet two cases of beer, a bottle of Jack Daniels and a qt of moonshine that you didn't clean the contacts completely. You probably just tried to clean the contacts thru the port, if so take the computer apart, it only goes back one way.
Old Jul 15, 2001 | 07:39 PM
noelvm's Avatar
Three things can cause this.
1. As stated above you did not clean off all the protective coating.
2. In you zelousness not only did you clean off the protective coating but you also cleaned off the silver contact strip. Be careful.
3. Remove and reinstall chip. Slide all the way up. If doesn't work. disconnect battery and slide all the way down. DO NOT TRY AND SLIDE WITH CHIP IN AND BATTERY CONNECTED.
4. Truck starts ok with chip removed and you have tried above, send chip back.
noelvm
Road Rash's Avatar
I'll see your 2 cases and raise you a barrell
Got to get them contacts clean!
Mike
Old Jul 15, 2001 | 07:53 PM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
I see your bet, and raise you a shot of...
Nitrous, j/k
dont forget to tape that thing to the computer.
Old Jul 15, 2001 | 08:00 PM
LTNBOLT's Avatar
Cool
If the bracket that holds the pcm is the same on the 2001 then you might need to bend the edge of it straight so the chip will seat properly.
Old Jul 15, 2001 | 08:18 PM
lightning Jeff's Avatar
Make sure your chip is for a 01
Old Jul 15, 2001 | 08:46 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Re: I see your bet, and raise you a shot of...
Use a six inch half strip of good ole duct tape, electrical tape stretches.
one more thing to check.
Did you reattach the wiring harness to the PCM?
Old Jul 15, 2001 | 09:15 PM
Flintstone's Avatar
Question
lightning jeff
was it your truck that had the trouble at stanton
with the chip and truck would not start.
just wonder what was the out come dan
Old Jul 15, 2001 | 09:29 PM
Talking
ok....i owe some folks some beer.
many thanks all !!!!
removed the chip, re-cleaned, scraped andbuff the connectors one more time........ hit it with some alcohol too.
this time, i also did the headlights on with the computer reconnected and battery disconnected to fully reset the computer.
i am not sure which one of these, or the combination of both did the trick, but either way, works now..............AND BOY DOES IT WORK!!!
this thing hits HARD now! sotp dyno says gooo things. i love it.
thanks again for the info guys!
Old Jul 15, 2001 | 09:50 PM
noelvm's Avatar
We'll bill you.
Old Jul 15, 2001 | 10:10 PM
Dean
I have a paypal account you can use for payment..... LOL
Glad it is working for you
Doug
Old Jul 15, 2001 | 10:18 PM
flinstone
that was not my truck, It was Darrells truck. He had to get a new computer for his truck.
Old Jul 15, 2001 | 11:11 PM
2_FAST4U's Avatar
I also had that problem with my '00. All the gauges would go to the right and the truck would turn over and over. It ended up that the chip I had recieved was for '01. Once I got the right chip it started fine!
