ok i need help trans is acting bonkers
Old Feb 26, 2009 | 01:21 PM
rhett28's Avatar
lol yeah thats what i was afraid of and it has plenty of fluid in it and im just trying to rule out the possibillity of me replacing the whole trans
Old Feb 26, 2009 | 01:22 PM
rhett28's Avatar
Originally Posted by Hostile03SVT
It looks like it is showing signs of internal failure. Have you ever had the transmission out of the truck for you to have any issues pertaining to this?
no but i bought the truck about 6 months ago and the guy who had it b4 me actually put a new motor in it so who knows what happen
Old Feb 26, 2009 | 03:37 PM
rhett28's Avatar
OK i found out why my truck was not shifting into first, the lower shift cable bracket was missing a bolt and was flopping all over the place, now i can shift through all gears and the orange marker even reads correctly, but now that i drive it again it feels like it is shifting into first but that might not be the case, it feels like a transbrake has been activated while im moving, the trans mission like binds up for like 5 secs and then breaks free and does that over and over again without missing a beat, anymore ideas im runnin out?
Old Feb 26, 2009 | 07:15 PM
Hostile03SVT's Avatar
Now that sounds like your converter is shot. It seems like it is slipping, the clutches in the converter may have snapped, or your pump on the transmission isnt moving the fluid through the converter until it builds up pressure.
Old Feb 26, 2009 | 07:35 PM
rhett28's Avatar
that makes sense i guess my next stuff is to drain the fluid to check for smashed up tourqe converter, and is this pump replaceable and where is it located?
Old Feb 26, 2009 | 08:14 PM
You have to remove the trans from the vehicle. It is part of the front cover of the transmission where the input shaft is. Your looking at a rebuild or a new trans if there is broken clutches going through the trans. Hopefully you do not, drain the fluid remove the pan, inspect the pan and filter for metalic dust particles at the bottom of the pan as well. That will tell you if your trans will live or most likely die.
