Help me out,slow 1/8 and I need to beat my friends Camaro SS!
Old Nov 18, 2008 | 10:14 PM
bluevenom867's Avatar
Hey guys,its been awhile since I been on ,anyway,I got to take the L to local 1/8 track and get in 5-6 runs. First my mods,then the aproximate et/mph and 60'
1999' SVT Lightning
136k odo
MODS:
K&N filter,open element
C&L MAF (its aluminum,not sure on size)
4lbs lower pulley
boost bypass w/ properly set actuator
stripped rotors and cleaned intercooler recently
PCV deleted last week with breathers (sealed all other lines/holes)
NGK TR6IX Iridium plugs
1 3/4" long tube headers,cerm. coated
no cats,no rear o2's
Bassani cat-back
built trans by me (LFP stage 1 rebuild kit) and FTVB w/ 4x4 pan,-06AN lines and a BIG B&M cooler. Its built perfect.
4:10 gears
Predator w/ some tune JLP did for me years back befor I had everything below the pulley + gear.
Old Goodyear F1's w/ about 38psi in em
fresh 5w-30 RoyalPurple and fresh coolant,distilled water w/ 2 bottles of water wetter in the intercooler res.
it was decent temp. wise for Pinellas area (mid 70's),but the humidy was high,close to 85%
TIMES:
First run I know I spun,ended up with a 2.3x 60' ,shifted into 2nd and rear got sideways so I pedled. Still ran like a 9.2 at 79mph,truck was warmed-up.
Ok 2nd run,I did a decent burn out,felt like it hooked ok (buddies said I spun some) got a 1.97 60', 2nd spun just a little @ the switch and I ran a 8.73 @ just a hair under 81mph.
The other four runs went just like the second,with the truck in the 8.7's and 1.9-2.0 60' @ just under 81mph.
I was messing with the Predator today and found my WOT spark adv. to be only @ 13*,I put that up to 16.
I also leaned it out in the MAF curve by 3%,and don't hear an signs of detonation @ WOT (street tuning) and the exhaust smells cleaner.
My question is,would I be better off with a canned Pred. tune and moding it or trying to figuer out this current baseline,witch I think might be close to stock.
Old Nov 19, 2008 | 01:24 PM
SVT_OFFICER's Avatar
whats your altitude?(where you live)
I did 8.6 (completely stock 02 L) at my local 1/8 track
and with a loose accessory belt.(it was the original one)
Also i think you might consider lowering your back tire pressure. Especially with old F1's.
I had brand new hankooks when i raced and lowered them to 25psi and ran with very little spin.
You have a lot of mods. (wish my truck had all that)
YOu should be running alot faster because i have a friend with an 00 L and a 4lbs pulley and he devowers ME!
Old Nov 19, 2008 | 04:24 PM
I forgot it wasn't on my profile,I'm in west coast FL,like 8ft above sea level...
Old Nov 19, 2008 | 05:18 PM
Black02SVTL's Avatar
I'd call JLP or JDM and get a retune if you dont want to go for a dyno-tune. But I wouldn't mess with the tune myself. Just my .02
Old Nov 19, 2008 | 05:45 PM
You think that that would get me at least into some low 8'snd still be o.k. on the street? Also how much are these mail tunes usually?
I called a local shop and they said $450 to dyno tune my truck,I said ******* THAT!
