Which ATF fluid?
Called SVT and they said whatever the manual says. I like to run Mobil 1 ATF $6 bucks a qt. has to be great stuff... What do you think? I am installing a +3 qt B&M pan.
01' Silver Bullet
Bought 03/31/01
Tire shredding truck
Prototype ram air 5/03 testing... Works GREAT!
Retrax cover 5/5/01
Wet Okoles 6/04/01
Looking for a chip and pulley soon.
01' Silver Bullet
Bought 03/31/01
Retrax cover 5/5/01
Wet Okoles 6/04/01
My owners manual says to use Mercon. I have been runing Mobil 1 Synthetic ATF since 1K miles. Here is a link to the product data sheet for it: http://dallnd6.dal.mobil.com/GIS/Mob...b?OpenDocument
Hope this helps
01 Silver Lightning
Delivered 3-20-01
12.61 @ 107.56
Hope this helps
01 Silver Lightning
Delivered 3-20-01
12.61 @ 107.56
It says what to use right on the handle of the dipstick. It will say MERCON....don't use mercon V. Also there is a plug on the torque convertor that you can remove so that most of the tranny fluid is drained. Hope this helps...
DRIVE IT LIKE YOU STOLE IT!
DO not use anything but Mercon III, I personally do not use anything expensive for the tranny, and I run a pan that is 5 qts. larger than stock.
I simply use HAVOLINE, and change the Trans fluid every other engine oil change.
Isn't Dexron III for Chevrolets?? Mercon III is for Fords?
2000 Black Lightning
14.026@97.12--Bone Stock
01' tail lights
Borla cat-back system
Lebra Tonneau
JDM 90mm MAF
JDM Oil Breather
JDM Flip Chip
kylerobeson@hotmail.com
my web site
Statistics show black is the fastest!!
01' tail lights
Lebra Tonneau
JDM 90mm MAF
JDM Oil Breather
JDM Flip Chip
my web site
Why does the Lightning FAQ referred to by this site say the Lightning uses Mercon V, when the correct transmission fluid is Mercon. Using the wrong type of fluid will ruin the transmission, right?
Seems like a very large and potentially costly error in the FAQ, that should be corrected ASAP.
I've talked to someone who is intimately familiar with these transmissions and here's his explaination to why someone have found Mercon V fluid when they sent in tranny fluid to be analyzed:
"The correct fluid is Mercon. At the factory we use "H oil" which is a special break in oil not available commercially. At the factory, we also build the 4R70, which gets "B oil" the equivalent of H oil for Mercon V, and there is a tolerance for the two being mixed in the transfer system, (we get it by the railcar, and sometimes the two get cross contaminated). Anyhow, it is possible that some Mercon V could be in a 4R100, and up to the given spec that's okay, but the service fluid is definitely Mercon, and Mercon V should not be used."
I looked in the SVT owners supplumental booklet and it says in big BOLD type do not mix Mercon and Mercon V fluids. Don't know where I thought of Merc V from. Anyway I will either go with Ford Merc. or Mobil 1 ATF. Since I will change it regular I may opt for the cheaper Ford Merc. Talked to JL yesterday and he says that he runs synthetic in the motor and rear diff but not in the trans...
01' Silver Bullet
Bought 03/31/01
Retrax cover 5/5/01
Wet Okoles 6/04/01
01' Silver Bullet
Bought 03/31/01
Retrax cover 5/5/01
Wet Okoles 6/04/01
Just got to your local JiffyLube or similar place and have them fill it w/ their machine that transfers the old out and the new in.
Take your Mobil 1 Synthetic ATF w/ you and tell them to use that.
BfB
[This message has been edited by BfB (edited 07-01-2001).]
BfB
