Nub has been Zapped...
Old Jun 20, 2001 | 05:32 PM
JeffsLightning's Avatar
Post Nub has been Zapped...
If any of you are keeping up with the lower pulley thread you will know all about the nub on the blower belt tensioner. I originally bought a little longer belt but I still had the idle rattle with the new lower pulley. Today I remover the IC coolant tank and looked at the tensioner. You could see the small aluminum nub on the tensioner where it limits the travel of the arm. Mine had been hitting. I released the tension on the belt and removed the 3 screws(10mm) that hold the tensioner to the block. I took my dremel and cut the nub off. Put the tensioner back on and there is much more stock travel now. I also put the stock belt back on with no problem. I really did not need the longer belt but now I have an exta I guess. One item of note was that one of the IC coolant lines was running directly in front of the tensioner when I went to pull it. I thought this routing was abit odd since it was rubbing on the tensioner arm every time the arm moved. Well low and behold Ford had the hoses routed incorrectly from the factory. I drained the coolant and pulled the bottom hose off of the tank and re-routed the hoses like they should have been from day one. Now there is no hose that comes close to the tensioner arm. This was a build f*c*up if you ask me. When you look at the front of your blower tensioner you should NOT see a hose laying on the arm...if you do then yours is routed incorrectly also. I also think most of the noise that people are hearing with the lower pulley was always there but now you hear it because the big rubber isolator on the stock pully is gone...
DRIVE IT LIKE YOU STOLE IT!
hud@mc.net
Old Jun 20, 2001 | 05:49 PM
Spiro99SVT's Avatar
Post
here's a PIC of my tentioner...with no "NUB"
Spiro-THE"GREEK"
12.37 @ 110.15@ 4700lb w/out the Go-Go juice
11.94 @ 115.31@ 4700lb with 100 shot Go-Go juice
11.40 @ 113 @4700lb with 150 shot(on the brakes)NOT BACKED UP 4700 lbs.
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
MONDAYS,TUESDAYS,WEDNESDAYS,THURSDAYS
@ 302-335-3326 10 a.m.ET-6 p.m. ET
VISIT TEAM POWER SURGE
[This message has been edited by Spiro99SVT (edited 06-20-2001).]
Old Jun 20, 2001 | 06:01 PM
Fast Gator's Avatar
Post
"To Nub or Not to Nub", that is the question!
1999 Black Lightning
  • 1940 of 4000
Traded for: 2001 Silver Bolt
  • Adopted 3/24/01
  • Red Line Water Wetter
  • Wet Okole's
  • Bed Rug
  • JL Stage II Ram air
  • Chipless in Jersey
OUT WITH THE OLD....IN WITH THE NEW
