Loss of Boost???
Old Jun 13, 2001 | 09:23 PM
HyE_BoLt's Avatar
Angry Loss of Boost???
Whats up guys. Was driving the L yesterday and gunned it from right around 20. Once it got to the shift, i heard a considerably loud "psssssssssss" (kinda like when a truck with air brakes stops). It felt like the truck was gasping for air after it shifted into second. I haven't really noticed this before, but mabye it's normal, mabey its not. Any input is appreciated.
Old Jun 13, 2001 | 09:50 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Post
If you were manually shifting it into 2nd, you probably hit the rev limiter. I did that once myself and the truck felt like it fell flat on its face. I just leave it in drive now.
Bob
Old Jun 13, 2001 | 10:18 PM
HyE_BoLt's Avatar
Post
Yea, now that i think about it, i did hit the rev limiter, but i still feel like i lose power at the shift if i just leave it in D.
Old Jun 13, 2001 | 10:33 PM
4D THNDR's Avatar
Lightbulb
It happens occasionally especially with a chip. It hits the rev limiter and the computer holds out the blower for a few (15?) seconds. Not a big deal unless you're munching on a Z28 or something.
Red '00 Lightning,
Power Surge Performance enhanced,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Old Jun 13, 2001 | 10:50 PM
99BLKBOLT's Avatar
Post
you can always disconnect the boost solenoid and you'll have boost without the fear of running a LT1 and hitting it and getting spanked... I know the feeling as I like to do a decent smoke show of the tires and I hit the rev limiter in the smoke show and ran a 17.05 against a 15.50 S-10... Pissed me off so the solenoid stays disconnected now...
Later, Justin
99.5 Black Lightning
Down's Filter
M/T ET 26-11.50R16
SuperChip FlipChip Tuned by JL
2# Lower Pulley from JDM
JBA Headers
Flowmaster 40 Series Mufflers
Best ET with slicks/filter/headers and 100 octane with R9 program side 2 13.48 @ 100.32 at GLD 5-3-01
Best with stock tires/JL tuned superchip/headers/filter and 100 octane on side 1 of chip 13.45 @ 102.29 at Gateway on 5-20-01
Old Jun 14, 2001 | 02:11 PM
alphadoggy's Avatar
Question
Anybody got pics or instructions for disconnecting the solenoid? Is there any danger of hurting the motor by doing so?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit, cam bolts, Jackson washers, Wet Okoles, Kenyon transmission
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
Old Jun 14, 2001 | 02:47 PM
99svtlightning's Avatar
Post
It's located almost directly behind the intake on the firewall. I don't have a pic. It's there to cut boost in case of an emergency. It's ok to unplug it to race, but I would plug it back in for long trips. It opens a "relief" butterfly on the back of the intake when cruising to allow air to skip the blower, therefore allowing cooler uncompressed air into the motor.
99 Lightning- JL equipped! JL Ram Air, JL Daiblo Chip,90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, NGK's. 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
New times w/ JL converter coming soon!
Old Jun 14, 2001 | 03:04 PM
NeedFourSpeed's Avatar
Post
There is also a way to run a by-pass which allows you to keep it connected. Haven't taken the time to do it yet or figure it out. Anybody out there have a step by step?
