easy belt install after PSP lower pulley
Just got the PSP lower pulley installed this morning. I had heard it can be difficult to re-install the stock belt with the bigger pulley. I had read several suggestions on how to get it done, but the belt seemed too tight for either of them. What I did was to remove the driver side idler pulley. Have a helper pull the tensioner and install the belt on all the other pulleys. Then just slip the idler pulley back over its shaft. It was almost too easy. Worked for me!
Hey - If someone else already suggested this...sorry for the repeat.
Thanks Sal/Spiro! Quality kit, great instructions! Noticeable improvement. No track times yet, hopefully soon.
chuckw
chuckw
Chuck, Napa sells an eight ribbed belt just like our stocker but a few millimeters longer. When it is installed with the PSP lower pulley your belt tensioner will be in the exact same location that it was when the stock pulley was on.. If you want I can get the part number... Jeff
99.5 Lightning
Gone but not forgotten
01 picked up on 5/5/01
hud@mc.net
99.5 Lightning
hud@mc.net
Glad your happy with it. I look forward to getting them all out there. Some have had a problem reinstalling the OEM belt, I did not for some reason. A larger belt wuld not hurt, but I am glad to have it slightly tighter than before. I now dont get that "belt-squeal" like you get with a smaller upper during firm shifts.
Now get to that track and run some trips down the 1320
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with 100 shot Go-Go juice @ 4700 lbs.
11.40 @ 113 with 150 shot(on the brakes)NOT BACKED UP!
4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
Spiro-
12.373 @ 110.15
Best 60' 1.72
4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
longer belt no. K080670...i just instl'd it and my new psp pulley last sat.
2001 Lightning, silver, escort 8500, ranger 2950dx dual band radio, wilson 2000 ant., bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
"nothin' but a bunch a low-life white trash drinkin' too much cheap alcohol"
"I don't take s**t from guys who drive Lightnings," the cop said. "You're speedin' when you're sittin' on the parkin' ramp."
<font face="Verdana, Arial" size="2">Originally posted by jarmstro:
JeffsLightning,
I would like the number for the slightly larger belt.
Regards,
</font>
JeffsLightning,
Regards,
</font>
Maybe this is crazy to mention, but how strong is the blower's snout? I would think that too much pressure would cause premature bearing failure. I seriously think they would have overmade the blower for this fact though, but you never know.
BfB
BfB
I questioned my mechs about the added tigtness and if the stress would cause premature bearing failure of the blower bearing. He said that if we could get it on it would be fine plus it would streatch. Since they know they will have to fix it if its not ok I trust their judgement. I do like the idea of a slightly longer belt posted above. Thanks.
noelvm
"ANYTHING OTHER THAN 1ST, SUCKS" (D.Earnhardt)
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, CAL TRACS, MT ET Streets, best time (1/8) 8.19, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)LONESTAR RACEWAY 2000 ROOKIE OF THE YEAR, STREET STOCK CHAMPION 01-01 TO 06-01 LONESTAR RACEWAY
noelvm
That number is correct for the Napa belt. 080670 it's 1-1/2" by 67-5/8" or 28mm by 1715mm. Does anyone know the length of the stock belt? The part number for it is 1L3V-8620-AA The Napa belt with the PSP pulley puts the tensioner in the exact same location as the stock setup was.
99.5 Lightning
hud@mc.net
99.5 Lightning
hud@mc.net
Mine sliiped on like the factory........Strange but easy!!!!
