Anyone using Bass tubes in their trucks?
Old Jun 6, 2001 | 05:53 PM
Kyle's Avatar
Post Anyone using Bass tubes in their trucks?
I an currently using 2 10 inch JL subs. They came out of a much bigger box that sat in the trunk of a mustang. The bass was great in that car and I knew it would not be as good in the smaller boxes, but I really miss it. I was thinking to switching over to bass tubes, (possibly amplified) to get the hard hitting bass back. Any suggestions/recomendations would be great.. Thanks in advance... Kyle
Black 99 Lightning
Born # 442 of 4000 on 4/20/99
Limo tint all around
Clear corners w/superwhite turn signals
Xenon headlights and foglights
Blue street glow neons and headlight strobes
Full audio system thanks to Alpine,Kenwood,JL audio, and Pioneer
01 tails
3/3 drop
Black powdercoated grille by Trenz
Performance mods to come soon..
[This message has been edited by Kyle (edited 06-06-2001).]
Old Jun 6, 2001 | 10:45 PM
MaxPower's Avatar
Post
I've got a single 10w6 JL in the truck. Just built the enclosure Sunday - .7 cubic ft, sealed. Used 3/4" MDF. Powering it with a 500a2 Rockford Amp, it sees 3ohms from the subs dual 6ohm voice coils wired in parallel. IT HITS HARD. I couldn't imagine putting 2 in there, it'd be unbelievable.
My cousin has a 10" Bazooka in his car that doesnt hit nearly as hard as this JL. You'd never fir it in the truck, too damn big. You'd lose at least 2-3 clicks on the seat to get 1 in. Do 2 and forget having the driver seat all the way back.
I did some research before deciding on the JL, and 2 8" Bazookas would have been the only answer. I decided not to go that route due to my good experience with JL, and not being overly impressed with Bazooka.
To each their own, but I'd recommend using 2 10w6's. You can build a box that will fit across the back, retain the seating positions, and have more bass than you could ever want.... unless you already have w6's, then you might not have the correct sized box, too low power, or a frequency cut-off too high.
Hope that helps a bit.
Old Jun 7, 2001 | 08:59 AM
Wyldman's Avatar
Cool
I am using a single 6.5" Bazooka tube behind the passenger seat and Kenwood Excelon 5 x 7's in the place of the factory speakers and it sounds real good to me. Not a lot of room inside the cab to fill with sound.
The
<A HREF="http://www.haloclub.com" TARGET=_blank> </A>
wyldman@houston.rr.com
Black 99.5 Lightning Build # 1273, DOB 5-14-99, NLOC #315
Old Jun 7, 2001 | 11:15 AM
Big Poppa's Avatar
Post
All speakers and amps are not created equally.. ( We all knew this )
Two good subs ( JL Audio, Kicker, Fosgate, etc.) and a good amp ( Fosgate, Alpine, PPI, etc. ) will sound good.. I have two 8" JL audios in my L with an Alpine v-12 amp pushing them.. It will not make your nose itch but, I find myself turning it down after a few minutes of high volume play..
I would stay away from the bazookas.. they may be loud.. but they are not that clean.. and when you put some power to them.. the blow pretty easily..
Just my 2 cents..
Got Boost ?
1999 SVT Lightning
Old Jun 7, 2001 | 07:31 PM
LoCo F150's Avatar
Talking
Dont waste your money on the bass tubes...they usually suck.
Old Jun 8, 2001 | 08:28 AM
water73's Avatar
Thumbs up
I had a self powered 10' and 8'bazooka tube in my l and was not impressed. bass was very distorted. switched to a single MTX 10'in a sealed box with a MTX 2200 series amp pushing 250 to the sub sound really good. I listen to a wide varity of music,rock to classic to rega. I have not been disapointed yet.
personal preference has allot to do with it. What sounds good to me may not to you. I am a fan of quick hitting bass, not much for the long lingering bass. I know the box can be built to fit behind the passengers seat and not loose any space. Good luck let us know what you finally do.
water73
DiabloSport Chip
K&N Drop-in
BedRug
good luck.
Old Jun 9, 2001 | 12:50 AM
bambino's Avatar
Post
I have Kicker self amped tubes in mine, and it flat out impresses people with the way that it sounds. Combined with Fosgate Components up front for clarity, the system sounds incredible.
I did it after a buddy of mine had the same setup (almost) in a 95 Reg Cab Ford. You'd have to hear it to believe it. Even the local Audiophiles are impressed.
hth
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; 40 chan CB/Maxrad Antenna; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
