01 lower control arm not sloted!!
Old Jun 6, 2001 | 10:25 PM
Busa's Avatar
Post 01 lower control arm not sloted!!
I bought a set of Herbs washers and was going to install them on my 01 born 04-01. The lower control arm is not sloted. Has anyone else experienced this? The ROUSH suspension works very well! It lowered mine about 2 in the front and 1.5 in the rear.
Old Jun 6, 2001 | 10:42 PM
Undy's Avatar
Post
I'm doing it the easy way. I'm going to take my 01 in to the dealer to check/set the alignment and right away drive it home. When I get home I'm going to fire up the mig welder and tack weld the washer to the lower control arm on both sides. It's a free fix and it'll never shift again. If I ever need to move it all I need to do is use my small pnuematic grinder and get rid of the tack weld. After welding I'll wire brush both sides and hit them with some spray undercoat to eliminate the possibility of rust..
2001L, red, born 2/6 and arrived 2/28!!!
JDM chip
12" Big Mouth filter
Magnaflow
Wet Okoles
Bedrug
Pro-Sport Lid
Let the mods begin....
1969 Vette coupe, 496ci stroker big block, aluminum heads, 4340 crank & H-beam rods, JE 10.8 pistons, roller everything, McLeod dual disk clutch w/ aluminum flywheel, Richmond 6 spd, 3" dual exhaust, 300hp nitrous fogger, much, much more.
LS1 eater.. big time!!
1985 FoToLet, work truck, 85 Toyota 4x4 (started as), Reading bed, ladder racks, 8" lift, 33 x 12.5's, Vette 350 4 bolt motor, Hooker Super Comp headers, Ford 9" rear, Toyota front diff, turbo 350 coupled to a Toyota transfer case, 410 gears, a/c & power steering. f-a-a-s-t A/C & heat calls..... my specialty.
web page: http://personal.picusnet.com/undy
Old Jun 6, 2001 | 10:59 PM
Snakepit's Avatar
Post
My 01 control arm is indeed slotted. I did what Undy said.
2001 silver Lightning
'69 Mustang GT
'82 Mustang GT (drag)
'48 Ford F1 pkup
Old Jun 6, 2001 | 11:10 PM
BfB's Avatar
BfB
Banned For Rules Violations
Post
I have yet to crawl under mine to see. Are you able to tell by just looking at it?
The '01 black I test drove before I bought my new silver was slotted. This was two different dealers, though, meaning they will prob. be two different build dates.
I'll go out and check in a few for my build date and my control arm.
brb in a bit.
BfB
Old Jun 6, 2001 | 11:16 PM
gforce's Avatar
Exclamation
Undy,
I tack welded too 9,000 miles ago and all is fine. Just a word of advice - make sure the bolt is centered and then weld before the alignment. Otherwise, it could shift on you before you get the chance to weld it, thereby screwing your alignment up. But, not a big deal, just re-align and all is OK.
Old Jun 6, 2001 | 11:52 PM
BfB's Avatar
BfB
Post
Mine was born 4-01 as well. I can't see where the slot would be. It's too low so I cannot tell.
BfB
Old Jun 7, 2001 | 06:55 AM
ASVTFordBoy's Avatar
Post
Where do you find the build date?
2001 Black Lightning
picked up 3/20/01
14% tint sides and rear
Line-X Bedliner
K&N, 26 X 10.5 M/T ET Streets and more to come
Best E.T.: 13.462 @102.30 (actual time slip)
Best 60': 1.93
Old Jun 7, 2001 | 08:18 AM
awhittle's Avatar
Post
There is one date on a sticker on the motor near the stering column. Also look on the bottom of the window sticker (this one does not have slashes and dashes so you have to look. also call svt a with the s# and they will sent you a certificate of ownership with the build date. All thes dates will be within a few days. How knows why?
Andy
Old Jun 7, 2001 | 08:50 AM
clonetek's Avatar
Post
if Busa has a Roush suspension on his lightning, then he may not have a slotted control arm.. why?
a Roush lowered suspension kit may replace the factory control arms, springs, leaf springs, swaybars, and shocks. (not too sure on what all it replaces)
a pic of a stage 1 Roush F-150
Old Jun 7, 2001 | 09:07 AM
Red Racer's Avatar
Talking
Good thinking, but incorrect. The slots are NOT in the control arms. The slots are in the control arm attachment brackets that are a part of the actual frame.
So even if you do replace the factory control arms, springs, leaf springs, swaybars, and shocks, the slots would still be there.
Old Jun 7, 2001 | 09:42 AM
clonetek's Avatar
Post
i stand corrected.. what the hell was i thinking? i can only blame the graveyard shift that i am working.
all i had to do was look at the pics i took over a year ago..
Old Jun 7, 2001 | 10:31 PM
Busa's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by clonetek:
</font>
The Roush kit only replaces the springs and shocks front and rear not the control arms. No slots in the frame at all took the bolt all the way out while installig the springs!
Old Jun 8, 2001 | 12:48 AM
action 911's Avatar
Post
Red Racer,
You beat me to it. You are absolutely right. New control arms won't change a thing.
Herb
