Widest Tires For 18 x 9.5 Rims
Old Jun 5, 2001 | 05:12 PM
D_Coburn's Avatar
Post Widest Tires For 18 x 9.5 Rims
What are the widest tires (e.g. 305, 315, etc...) that would fit on the stock lightning rim?
Thanks,
Dave
Old Jun 5, 2001 | 05:58 PM
awhittle's Avatar
Post
This might help a little
http://www.toyo.com/tires/tire_lines.../specs/st.html
or
http://www.secret-secret.com/turbo/D...turbotire.html
Generaly the wheel should be about the same width as the tread. If the wheel is wider then you will always be replacing wheels every time you touch a curb parking. If the wheel is any narrower the tire will wander.
Hope this helps
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
Old Jun 5, 2001 | 08:45 PM
D_Coburn's Avatar
Post
Thanks for the help Andy. I have called 3 different tire shops, and nobody knows the answer. They always tell me that they think that 295 is the biggest tire that would fit on a 9.5" rim, however, they are not sure. Now I know.
Thanks,
Dave
2000 White Lightning
PSP Filter, Chip
Bassani Full Setup
410 Gears
