keypad ???'s
just entered an door lock keypad on my 2000 L, looking for the white control module for the 5 digit number, and should i be able to find it without removing any interior panels..thanks
-White 2000 L, stock, currently, 17.6k miles and having more and more fun with it everyday.
-1991 ford mustang lx conv.
stage 5 Kenny Brown suspension.
302 short block, twisted wedge heads with street fighter port.
Cobra upper and lower intake.
Vortech 8psi huffer.
190lph felp pump with t-rex helper.
36lb injectors.
3.73 geared.
AOD trany customized by the local seeed shop, (Alternative Auto).
Battery Relocated.
2 1/2 inch. off road exhaust.
approx 400hp and always going up, not exact numbers not been on a dyno yet.
Hasnt been to strip, being built for the turns..
36lb injectors.
3.73 geared.
Battery Relocated.
L in Detroit:
If you are talking about the door pad your truck should have a card with your factory set code in your owners manual. Its a white card that has your code for the keyless entry system. Mine is a 2000 lightning and I had it anyway. Good luck and I hope this helps.
my zing albums- _-click here-_
'00 harley davidson FLSTC tons of custom parts..
'99.5 nissan pathfinder le-STILLEN EQUIPPED
'88 toyota show truck(TONKA)
'91 toyota mr2 turbo (to many mods to list)
'00 yamaha banshee(toomy race kit/chrome pipes)
bought truck used and didnt get mush paper work with it, just the owners guide. aslo heard the number was on the door lock module under the dash.
which brings me to anothe question, is there a way i can get the SVT documentation which is sent to the original owner, bought from a dealership and not in contact with the original owner..
36lb injectors.
3.73 geared.
Battery Relocated.
36lb injectors.
3.73 geared.
Battery Relocated.
The 5 dig. code is under the dash by the steering column on the control box. If you get down there with a light and look you can't miss it.
A copy of the orig. window sticker can be had at the orig. dealer it was sold. If you don't know which one it was, call 1-800-FORD-SVT and ask them. They will prob. want your VIN and proof that your the owner. They can also get you the certificate of your production number.
