Pod coming - what gauges?
Old May 28, 2001 | 11:45 AM
Madhouse's Avatar
Post Pod coming - what gauges?
I've got a Lo-Tek double-gauge pod coming in the mail. What gauges should I be putting in it - I know I want a trans-temp gauge. What else, maybe an accurate boost gauge? This is a non-N2O application...
<A HREF="http://users.ev1.net/~temurphy/lightning/" TARGET=_blank> </A><A HREF="http://haloclub.svt-lightning.com" TARGET=_blank> </A>
2000 Black Lightning
#4399
Old May 28, 2001 | 02:36 PM
Madhouse's Avatar
Post
that's a good point...
Old May 29, 2001 | 12:09 AM
Ruslow's Avatar
Post
No boost guage.After what happen to me it would be an air fuel ratio guage.What can you do to get more boost if you are running wot anyway?But if you are lean then you can back out of it and save your motor!Alot of the guages like the boost guage tell me nothing that I ALREADY know,when the needle moves I know I have boost.But what about being LEAN?
Old May 29, 2001 | 10:24 AM
NeedFourSpeed's Avatar
Post
The ai/fuel gauges aren't worth a crap as far as accuracy.
If you don't want boost then how about fuel pressure?
Old May 29, 2001 | 10:36 AM
Madhouse's Avatar
Post
I'm not opposed to a boost gauge - I kind of wanted the second gauge to be one that moves alot. I really wanted the trans.-temp and I think the double pod is cool, so the second gauge is just gratuitous unless there's another that's necessary...
Old May 29, 2001 | 10:41 AM
MRBBQMAN's Avatar
Post
I agree with Ruslow, the A/F is the most important gauge on this truck. buy it here http://www.gadgetseller.com/gauges/ or send yours to them for calibration. they come back "very accurate"
Old May 29, 2001 | 11:17 AM
Spiro99SVT's Avatar
Arrow
I personally would run a fuel pressure guage. This to me (along with a properly calibrated A/F guage)are the most important to monitor. Or go one step further and install a EGT to properly monitor your A/F.
MOST aftermarket A/F guages are for show only, and DO NOT help in way, unless your looking for a light show
I have run a mechanical fuel pressure guage on the outside of the truck...right in the line of sight, and it has helped me twice in pinpointing a problem.
Not to mention there have been many of us here that have had a PUMP assembly go bad.
And for the second one..go with the TRANNY temp guage...IMO
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with 100 shot Go-Go juice @ 4700 lbs.
11.40 @ 113 with 150 shot(on the brakes)NOT BACKED UP!
4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCE
Sales@POWERSURGEPERFORMANCE.NET
Old May 29, 2001 | 11:37 AM
MRBBQMAN's Avatar
Wink
an electrical fuel pressure gauge mounted in the pod, is worth about as much as an "off the shelf" A/F gauge. the only fuel pressure gauge worth a damn, is a mechanical type, which must be mounted outside, as Spiro suggested. still need to fill that hole
Old May 29, 2001 | 01:28 PM
Ruslow's Avatar
Post
Fuel PSI gage is not telling me anything if I already have an EGT or A/F guage.If you are down on fuel psi then you are up on EGT and a/f will lean out.EGT guage is another good one [have one on my diesel],but put it so that it reads more than one cyl and AWAY from the cats!!!
Old May 30, 2001 | 07:32 AM
Madhouse's Avatar
Post
I guess I'll just put a clock in there... j/k, of course.
Old May 30, 2001 | 09:10 AM
Ruslow's Avatar
Unhappy
I know the feeling!!! But put in what you want!!! What I am telling you is only a suggestion and it is your money your truck and your guage pod.Good Luck,Stan
