RETRAX critique
Old May 22, 2001 | 11:35 PM
L8 APEX's Avatar
Post RETRAX critique
I have ahd my Retrax for almost a month and the 900$ price has not left my mind yet. I have seen a few draw backs to the cover. I knew my 4 wheeler would be close fitting but I have to run the tailgate down now I don't really like that. The rails where the bearings slide rust up between uses. Grease would suck dirt and get on my cargo at times. There is no good access to the rear allen adjuster screws. Don't exactly love the clamps but cannot knock them until I think of another way to attach it. It doesn't seal the rear to the tailgate the rest seems water tight but the rear seal is lacking it should be thicker and come over farther. I like it a lot and it gets a lot of attention.
01' Silver Bullet
Bought 03/31/01
Tire shredding truck
Prototype ram air 5/03 testing...
Retrax cover 5/5/01
Old May 23, 2001 | 02:34 AM
felonious's Avatar
Post
VERY not-waterproof!!! As I just found out last night... Still, probably more waterproof than no cover at all. I agree with you about those rear adjuster nylon bolts - don't even try to turn 'em once the cover is installed! There's just no way it's gonna happen. So I have some extra looseness back there, I don't think it affects anything.
Overall, I'd say I'm 80% happy with it. Along with the above flaws, the lock is ridiculously unsecure, with I think three pins? I could probably pick it in ten seconds.
I don't want to come across as totally Retrax-bashing though, 80% happy isn't too shabby for someone as particular as me.
-Ollie
"Our Lady of Blessed Acceleration, don't fail me now!!!"
-Elwood Blues
[This message has been edited by felonious (edited 05-23-2001).]
Old May 23, 2001 | 08:37 AM
Predator1's Avatar
Post
try putting 303 aerospace protectant on your rails--this is a vinyl conditioner but also works on the rails to keep down rust and helps to keep smooth rolling on top. i have a roll-n-lock cover and use 303 for protection and lube for rails.
2001 F-150 4X4 Supercab
XLT 139" WB style side
5.4L V8 3.55 LIMITED SLIP AXLE
MODS:
AIRAID FIPK
SUPERCHIP(FLIP CHIP)
ROLL & LOCK TONNEAU
being installed as of 5/22/01
GIBSON CAT BACK
GIBSON HEADER
REFLEXX COBRA HOOD
STREET SCENE GRILL
HOLLEY THUNDER SUPERCHARGE
PILLER GAUGES
Old May 23, 2001 | 10:55 AM
T Ellenberger's Avatar
Post
I adjusted the rear allen head nylon pieces with a set of needle nose pliers (gently, and without the clamp in place.)
Washed the truck yesterday and did not spray on top the the Retrax. I used Windex like the instruction sheet said.
Added a piece of Camper Shell tape to the top edge of the tailgate to help seal out dust. I could use the tailgate seal they sent because my BedRug covers the hinged area between tailgate and bed.
Don't feel too bad about the price. I took off a ******* cover that I had over $650 in to put on the Retrax. Now I need to sell the ******* cover.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, Retrax Bed Cover, BedRug, XL Full Length Running Boards,EGR Fender Flares, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old May 23, 2001 | 01:14 PM
FASTRK99's Avatar
Post
Any pics of this cover?
Old May 23, 2001 | 01:56 PM
felonious's Avatar
Post
There should be quite a few, posted to other threads on this board. Just search for "retrax" and that should bring them up. Feel free to ask if you have specific questions about the cover.
-Ollie
-Elwood Blues
Old May 23, 2001 | 03:13 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
Here are a couple pics of mine..
