Official service procedure for clunk?
Old May 9, 2001 | 04:48 PM
98Cobra's Avatar
Post Official service procedure for clunk?
Well, I looked at my truck service history in Oasis today and am not pleased. Way too many entries for 14k miles.
However, I found the actual real TSB to fix the "clunk". The disappointing thing is that my repair order in Oasis makes references completely different parts and labor performed on my truck. Unsurprsingly, its clunking again.
So, if anyone wants the TSB, which includes all the alignment specs for Lightning as well, let me know, and I will post it. I never saw this in the TSBs on www.alldata.com, and it was written Dec. 4, so its relatively new...
Old May 9, 2001 | 05:50 PM
cabraco's Avatar
Post
Please post with the alignment specs. Are the alignment specs the same for the 01. Lowered my 01 with the 3/4 bell tech and did Herb's washers. Takin' it in tomorrow for the cam bolts and alignment, and would like to know what the 01 specs are. Thanks
01L,Lowered, Black,Downey SST,Straight Pipes,Chipped........ Toy: 91 Heritage Softtail Classic/Lowered
Old May 9, 2001 | 06:03 PM
98Cobra's Avatar
Post
According to the TSB(which applies to 1999 and 2000 models), the specs are:
LH RH Total/Split
Camber -0.5" -0.5" 0" +/- 0.7"
Caster 6.7" 7.2" -0.5" +/- 0.7"
Toe -0.05 ++++/- -0.05 +/- 0.15 -0.10 +/- 0.25 (positive value is toe-in, negative value is toe out)
Tried to format that the best I could in this space....
Old May 9, 2001 | 11:10 PM
NOSTROMO
Guest
Posts: n/a
Post
Did ford eliminate the clunking problems on the 01?
Old May 10, 2001 | 12:48 AM
action 911's Avatar
Smile
NOSTROMO,
The problem is still there on the 01s. E-mail me at jacksonherb@hotmail.com I'l give you the info on a real outstanding fix.
HJ
Old May 18, 2001 | 05:45 PM
2000Black's Avatar
Post
Can you give me the TSB # for the clunk? I'm coming up on 12k miles and need to get mine fixed so I can take advantage of the one free alignment after the do the washer thing. Thanks!
2000 Black Lightning
#1326 of 4966
Born on 03/20/2000
PSP Chip
PSP Filter
Best time: 13.248 @ 104.4 mph
Old May 18, 2001 | 06:38 PM
1bnsfn's Avatar
Post
I would like the TSB as well. I'd appreciate it if someone would give it to me.
j.balensiefen@att.net
Old May 18, 2001 | 07:02 PM
cabraco's Avatar
Post
If you put in the "herbs washers" you must install the cam bolt kit, so that all the alignment is done from the top. Ford was locking in the alignment on top with fixed plates, and then setting the castor stagger with the slot on the driver's side lower a arm bolt. If you center the lower a arm bolt with "herbs washers, you need the cam bolts installed to set the castor stagger, as well as toe in and camber. Herbs washers won't work without the cam bolt set!!
01L,Lowered, Black,F1 Hood,Downey SST,Straight Pipes,Chipped........ Toy: 91 Heritage Softtail Classic/Lowered
