Steering Stops
Old May 14, 2001 | 04:18 PM
Snakepit's Avatar
Post Steering Stops
FYI, when you pick up your new truck. They do not come with grease on the steering stops. The factory left it for you to do
2001 silver Lightning
'69 Mustang GT
'82 Mustang GT (drag)
'48 Ford F1 pkup
Old May 14, 2001 | 04:38 PM
ally69's Avatar
Post
were exactly are they??
Old May 14, 2001 | 05:55 PM
Snakepit's Avatar
Post
They are the round metal blocks (about 3/4 in dia.) that come in contact with the backside of the spindle. You will see a slight indentation on the spindle where the stop meets it. Smear this indentation with about 1/4 in of grease.
Old May 14, 2001 | 06:53 PM
smokingozzy's Avatar
Post
snakepit, One of mine was greased and one was dry.When I backed up with the wheels cut sharp I heard a snap,after I greased the dry one the noise stopped. Go figure!
Old May 14, 2001 | 07:26 PM
Flintstone's Avatar
Post
service writer showed than greased mine
Old May 14, 2001 | 09:06 PM
Fast Gator's Avatar
Cool
One word::: Never-seize
1999 Black Lightning... 1940 of 4000... Traded for: 2001 Silver Bolt... Adopted 3/24/01... Red Line Water Wetter... Wet Okole's... Bed Rug... JL Stage II Ram air... Chipless in Jersey
Old May 15, 2001 | 08:49 AM
LIGHTNINROD's Avatar
Post
raised frontend at crossmember-turned wheel to one side-located "stop" on lower control arm-covered it with c/v grease left over from saab 9000 turbo. repeated for other side. don't need to get under truck-can reach the stop from rear of tire. dan
2001 Lightning, silver, bot/picked up on 05/08/01, 1997 f150 xlt 4.6L 4x2 with: a/f one fipk, superchip, optima battery, bbk 75mm throttle body, edelbrock ias shocks--2001 lightning to come(she came--see above)
