I know, I know, Lowering questions again..
Lot of people have used this setup, but it would not be my first choice. If you drop more than an inch or so in the front with a spring or control arm drop, you will end up blowing out the stock shocks. The bump steer also gets worse the more you drop. Finally, the Belltech springs are of unknown rate and quality. A common mistake made by many in these parts is increasing the front spring rate. Considering that our trucks already understeer like a pig, that's a bad move. If anything, it's the rear rate that needs to be increased.
Unless you go stupid low in the front, there will be no wheel clearance issues with any drop kit with 295/40-20s.
Ah ok, the guys telling me that if I do the 2" spindles in front and 3" shackles in back and leave my stock shocks I should be fine, and if i later want to replace the shocks i have the option. Keep in mind my stock shocks are practically new, only 7,500 miles.
...but that's just my .02
3/3 drop
3/5 drop
my current 3/4 setup w/ 255-65-16
same 3/4 just lowered off of lift with new tires, springs hadnt settled back down fully
3/5 drop
On the rear, you would need SoCal or Belltech shock extenders to avoid damaging the shocks. That's only a $50 expense, though.
The spindle/shackle combo would be fine, and does a better job of handling bump steer than the FRPP kit. It just costs a little more in parts and labor.
Thanks guys,
I end up going with the belltech spindle/shackle drop with the shock extenders. Getting installed in about 1-2 weeks,then off to Krown, then hooking up some new rubbers and im done(for now) sweet!
Thanks guys,
then again it COULD be the traction bars and bigger sway bars... but i don think it is
Originally Posted by crash_lucky13
dude don't trust the shocks....i got the bilsteins and my ride is ROUGH....
With a spindle drop in front, and a mild drop and extenders in the rear, the Bilsteins will work the same as stock -- which is to say very well.
I'm guessing you aren't shooting for a serious road handling/autocross drop. If this is the case, the Belltech 2/2 drop (springs and shackles) will leave you with a nice rake. Here are some pictures of mine with 18's and 22's for reference.
You would probably have about the same stance with what JDM suggested to you.
Originally Posted by Tim Skelton
You have a "3/4" drop, right? Then there is no way that the Bilsteins are operating in their proper range. Can't blame Bilstein for that. As a matter of fact, I'll bet you have bottomed them out and destroyed the innards.
what was the shock that beltech offered with their kit about 3 years that was considered the "performance" shock... wasnt it the bilstein? or was it the nitro active? in my taste it wasn't worth a damn
Belltech is a curious company. Some products they make are awesome (e.g., its 97-03 C-notch). Some products are poorly engineered (e.g., its 97-03 spindles). And then some are just junk.
