RELOCATED BATTERY?? Must READ!!!
Old May 8, 2001 | 03:31 PM
Spiro99SVT's Avatar
Exclamation RELOCATED BATTERY?? Must READ!!!
I hope that most of you that have relocated the battery to the bed also have installed the proper "kill switch" on the rear of the truck.I know a lot have done this, so I fiugured I should remind everyone about this rule:
NHRA rules clearly state that any relocated battery MUST have the proper switch connected, and be clearly marked "OFF" in there is a need to use.So be smart, and runa switch. And also be sure that the truck shuts down as soon as the switch is flipped.
I just figured I should pass this information on. This is a NHRA track, and they STICK to the rules.
These switches can be purchased from any speedshop. Hope this helps. Lets have a safe and FAST week!!
Killa',
Got A Switch?
Spiro-
12.373 @ 110.15
Best 60' 1.72
@ 4700 w/out the Go-Go juice
11.94 @ 115.31 with the Go-Go juice @ 4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock Manifolds
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Sponsored by POWER SURGE PERFORMANCETitle Sponsor WFC4
Old May 8, 2001 | 03:46 PM
DJANIMATE's Avatar
Post
Also, when carrying the battery from the front of the truck to the rear make sure it's right-side-up, especially if your not wearing any gloves.
Adam
01 Black Lightning - JDM 'FlipChipenfiltered','Straightpiped', 'splitfired', 'billetted', 'Neoned', and 'Grooved' thanks to Blaupunkt, Alpine, Sony, Clarion, Dynomat, and MTX
Old May 8, 2001 | 04:20 PM
95 Saleen S351's Avatar
Wink
Also be sure to heat test the battery by tossing it into a VERY HOT fire first, before inserting it into your truck.
2000 Red Lightning
BedRug
95 Saleen S-351 Convertible/Triple Black
97 Kawasaki Vulcan 800 Classic
Old May 8, 2001 | 05:36 PM
bggroth's Avatar
Post
The proper way to check for a fully charged battery: run a long screwdriver from the positive terminal to the negative terminal.
Note: If you are a smoker: if you can light a cigarette from the resulting sparks, the battery WAS good when you started the test.
Brian
99 red lightning, bassani complete system #1610 of 4000
2001 Lightning, SVO throttle body
2000 super duty v10
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
My vehicles http://www.zing.com/album/?id=4293160925
[This message has been edited by bggroth (edited 05-08-2001).]
Old May 8, 2001 | 06:01 PM
Don C's Avatar
Thumbs up
You can get the kill switch at a marine supply store too.
Old May 8, 2001 | 06:22 PM
Madhouse's Avatar
Post
I bow to all your smart-***-ednesses, or something.
Old May 8, 2001 | 08:24 PM
JohnnyLightning's Avatar
Post
Thanx Spiro! good advice! you never know what and when they will check! JL
93 cobra 10.90@127.00
99 lightning (black)
E.T. 12.06
best mph 112
60 ft. 1.65
(All Throttle No Bottle!)
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
(KEEP IT BETWEEN THE LINES!)
F-150 Supporting Vendor
_ _ _ _ _ _ _ _ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
JohnnyLightningWebpage
Old May 8, 2001 | 09:51 PM
alphadoggy's Avatar
Question
Are you required to be a smart-*** before you can post to this board?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit, cam bolts, Jackson washers, Wet Okoles,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old May 8, 2001 | 10:03 PM
Post
Alphadoggy
Yes it was a checkbox on the application.
Old May 8, 2001 | 11:25 PM
Red Chief's Avatar
Question
Spiro or anyone who knows
Will any location accessible from the outside be OK? Can I put it in the passenger rear fender well? This would be the easiest since that is close to where I have relocated the battery. Thanks in advance for reply.
Old May 8, 2001 | 11:38 PM
LightningTuner's Avatar
Post
This is from the NHRA rulebook:
"Master cutoff switch is mandatory when battery is relocated. An electrical power cutoff switch (only one) must be installed in the REARMOST part of each vehicle and be easily accessable from the outside of the car body. The cutoff switch must be connected to the POSITIVE side of the electrical system and must stop all electrical functions. The off position must be clearly indicated with the word OFF. If the switch is push/pull type, push must be the action of shutting off the electrical system, pull to turn on. Any rods of cables used to activate the switch must be minimum 1/8 inch diameter. Plastic or keyed switched prohibited."
So basically, the switch must be mounted at the very rear of the truck, and cannot be plastic or require a key to turn.
**KEEP IN MIND- you cannot simply hook your positive battery cable to the cut off switch. The truck will continue to run if you disconnect the battery. You must also tap into the power to the PCM relay to be cut off as well, from the same switch, so the truck will stop running when the switch is used.**
SAL - TEAM PSP
web- www.powersurgeperformance.net
E-mail sales@powersurgeperformance.net
tech@powersurgeperformance.net
F-150 Online Supporting Vendor
Old May 8, 2001 | 11:41 PM
MadMaxSC's Avatar
Red face
AlpoDawgy...your funny!
Old May 9, 2001 | 12:18 AM
Spiro99SVT's Avatar
Post
As Sal stated, the info. is here for those that will need it.
Thank you
Old May 9, 2001 | 12:43 AM
Spike Engineering's Avatar
Post
Is this just an NHRA rule? What about road racing?
Spike
Old May 9, 2001 | 01:29 AM
Spiro99SVT's Avatar
Post
good question... I would think that it would be required as well. If your in a terrible road race accident, someone will need to cut the power if need be in a hurry.
Ruslow ?
