Speakers - All 4 or 2?
Want to replace speakers. Should I go ahead and replace all four or just the two door ones? Seems to me like the two behind the seats are pointless, so why replace them?
2000 Silver Lightning
#2798 of 4966
Born on date: May 9, 2000
Email: ColinMBurns@hotmail.com
Mods: SnugLid, 20% tint, Airaid, Slush Mats
My Zing Album:
http://www.zing.com/album/?id=4292724199
#2798 of 4966
My Zing Album:
I would replace them all...here is my reason: If you replace the front ones only, you will be more likely to have the volume higher since they will sound better and then you will surely blow the rear speakers. When you blow the rear speakers, you will definately notice them and you will realize that you can hear those speakers when you have a full setup running.
Good thinking. Any other thoughts? Pioneer sound ok for speakers?
#2798 of 4966
My Zing Album:
#2798 of 4966
My Zing Album:
I just replaced the door speakers only with some Pioneer TS-A6865's. The difference is awesome! Those stock speakers are garbage. This is just a start to what I'm doing with the sounds, but all I do is fade the sound to the front, so I don't blow the stock speakers in the rear deck. The Pioneers sound great, BTW.
Do the rears eventually, but you don't have to do them all at once...
<A HREF="http://users.ev1.net/~temurphy/lightning/" TARGET=_blank>
</A><A HREF="http://haloclub.svt-lightning.com" TARGET=_blank>
</A>
2000 Black Lightning
#4399
</A> 2000 Black Lightning
#4399
How easy is it to pull the door panels to get to the front speakers? If its not too bad maybe I'll change all 4. Thanks
99.5 Lightning
Gone but not forgotten
01 picked up on 5/5/01
hud@mc.net
99.5 Lightning
hud@mc.net
Anything is better than the original speakers.
I've taken the back speakers out and I'm only putting front components in. The void left by the rears made a great spot for installing other toys.
My Infinity Kappa Perfect components should be here tomorrow. Nothing's too good for my Lightning.
http://www.infinitysystems.com/caraudio/product.asp?ProdId='KAPPA+PERFECT6%2E1'&Ser=KPE&Ca t=COS
Mark
'00 Lightning
'79+ Corvette
Mark
'00 Lightning
'79+ Corvette
I got this same help from this board last week when I replaced mine...
There's a plastic piece on the door window frame that not a part of the door panel. It pops right off. Once that's off, there's a screw that you can take out. Then pop off the oval plastic piece around the inside door handle, it also pops right off. There's the second screw to take out. Then you can remove the panel with the door lock and window buttons - pop off the front edge first (the point) and pull up. Unplug the window and door lock controls and the door panel should lift and come right off. A hint, though: roll down the windows before you start - it makes it easier to guide the door lock back into place when you're putting the door panel back on.
Good luck!
</A>
#4399
Good luck!
#4399
last week I had 2 JL Audio XR570CX two-way speakers installed in the doors, just disconnected the rear speakers (which are a total waste of watts/space), put a JL 10" 10W0 sub behind the seats and a JL 300/4 amp pushing 75 watts to each door speaker and 150 to the sub. sounds AWESOME. If youre going to replace the speakers, even if you dont put in a amp, i would recommend disconnecting the rears (or you can always just put the fade all the way forward) and putting in some good 2/3 way speakers.
2001 Silver
BedRug & Snuglid Ordered
[This message has been edited by JBLsilver01 (edited 05-06-2001).]
2001 Silver
Madhouse,
Speakers make a big difference eh? I'm gonna try anything to get a better sound, but a little at a time. I was thinking of Pioneers also. I just wanted to know I wasn't wasting money.
Stevie-Ray
00 Red L #3460
JL Stage 2 Ram Air
Clear tails
Custom mats
ARE LSII
Bedrug
Keypad entry
Homedics Back Expert 2000
Stevie-Ray
00 Red L #3460
JL Stage 2 Ram Air
Clear tails
Custom mats
ARE LSII
Bedrug
Keypad entry
Gitchi -
It's not a waste of money. It won't get you show-quality sounds, but it's a big difference. Those Pioneers are kind of budget speakers (mine were $59/pr.), but they sound good.
</A>
#4399
#4399
I'd go with Polk audio. I have had Pioneer in the past and I had some Polks in my last car and they sounded bitchen!
Proud owner of a Silver 2001 Lightning!
Magnaflow 12468
******** X-2000
Synthetic
BaBolts Exhaust Tips
Magnaflow 12468
******** X-2000
Synthetic
Polks.... DX-7's in all four corners.
Even if you don't do a sub, you'll really enjoy the difference..
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, NGK TR6 Plugs, BellTech 3/4 drop, Ford MotorSport Chrome Lightning wheels, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 Lexus IS-300
2001 EB Expedition
Rich
2001 Lexus IS-300
2001 EB Expedition
I have had polk's db7 for about a year. They sound pretty good. I just bought Kenwoods Excelon KFC-X688C 5x7's. They sound way better than the polks. The kenwoods are rated at 220 watts, and the polks are 130 watts.The kenwoods high's and low's are way better than polks.If you are planning to hook up a amp to them i would go with the kenwoods. To answer you question i would take out your storage compartment and leave the stock speakers in the rear alone. I've found that the stock rear speakers sound better than the polks or the kenoods. For some reason they give off better, tighter bass than the other two. I have the stocks hooked up to my kenwood deck and my excelon's hooked up to a ads amp. I have tryed 4 db7's, and i think that the stock speaker's sound the best in the rear.
I still can't find any info. on Polk's site about a "DB7". I don't see anything on Crutchfield's either.
The Polk DX7's are 130W and work fine with an amp..
Casper:
To say the factory speakers sound better than Polk or Kenwoods speaker makes me think you have the polarity set backwards?
Stock speakers suck....
Just my .02
Rich
Casper:
Just my .02
Rich
