What's The Best Way To Remove Stock Fan?
Old May 6, 2001 | 04:42 PM
LTNBOLT's Avatar
Question What's The Best Way To Remove Stock Fan?
I don't want to reinvent the wheel so if someone would be so kind as to tell me the quickest and easiest way to remove the stock fan assy. Thanks.
Later,
Chuck
Black 00
Chuck's Lightning Page
Old May 6, 2001 | 05:15 PM
Spike Engineering's Avatar
Post
Tie a rope or cable around it and back up quickly.
Regards,
Spike
Old May 6, 2001 | 05:35 PM
LTNBOLT's Avatar
Wink
Spike,
That would be the quickest and easiest way for sure, LOL. Maybe I should have said without tearing anything up.
I when and reinvented the wheel anyway. 2 pipe wrenches and remove the supercharger belt to get it out of the way. Put one on the rusty shaft coming from the water pump and let it bump against the aluminum bracket that has the 2 idler pulleys for the supercharger belt. Put the other wrench on the shaft coming from the fan that's shaped like a nut about 1 3/4". Turn counterclockwise. By having the one wrench bump up against something then you can put all your a$$ into pulling on the other wrench. Once it snaps loose you can turn it by hand the rest of the way.
There it is in case anybody else wants to know.
Later,
Chuck
Black 00
Old May 6, 2001 | 08:59 PM
Lightningquick's Avatar
Post
How did you know which way to turn it/ Usually they are clockwise to loosen on Fords and the Lightning is like backwards from that.I though it was strange but anyway,you forgot to mention what a pain it is getting it out of the shroud
Old May 6, 2001 | 09:06 PM
Bolt's Avatar
Post
It's much easier if you remove the shroud at the same time.
Airaid, Spal Fan, FPPTB,PSP Pulley, Brembo's, R9 Flip Chip, Aluminum DS, 4:10's.
Old May 6, 2001 | 11:25 PM
LTNBOLT's Avatar
Cool
Everything running on the front side of the serpentine belt are usually clockwise (lower pulley) and everything on the backside of the belt (water pump and fan) are usually counterclockwise. Hope this helps.
Later,
Chuck
Black 00
