Which plugs to use?
Old May 2, 2001 | 11:59 AM
ATIDominator's Avatar
Post Which plugs to use?
I posted this on the NLOC board but nobody answered so I will try again here.
Here's a good question. It is common knowledge amongst supercharged Mustang tuners that the best way to go is with a standard Autolite/Motorcraft plug about 1 heat range cooler than stock. I have been told almost universally never to use a platnum or splitfire plug on my supercharged stang. I guess the reason is that they tend to foul easily. So why is it that the supercharged Lightnings tend to like these kind of plugs? Somebody please enlighten me!!
90 LX Mustang 5.0
-ATI Dominator D1B S/C 14 psi
-TFS Twisted Wedge Heads
-GT40 Intake
-BBK Shorties
-E303 cam
-70 mm TB
-75 mm MAS
-MSD 6 BTM
-Tremec
-Aeromotive fuel system
-3.55 gears
(505 rwhp , 495 ft-lbs)
2001 White Lightning
-magnaflow 12468
Old May 2, 2001 | 01:08 PM
DJANIMATE's Avatar
Post
haha, actually it's like having a 4 valves per cylinder or something like that.
Adam
01 Black Lightning - JDM 'FlipChipenfiltered','Straightpiped', 'splitfired', 'billetted', 'Neoned', and 'Grooved' thanks to Blaupunkt, Alpine, Sony, Clarion, Dynomat, and MTX
Old May 2, 2001 | 01:18 PM
95 Saleen S351's Avatar
Wink
No, its more like adding a second supercharger and twin turbos to your truck!
Should be good for 500hp.
2000 Red Lightning
BedRug
95 Saleen S-351 Convertible/Triple Black
97 Kawasaki Vulcan 800 Classic
Old May 2, 2001 | 01:36 PM
MRBBQMAN's Avatar
Thumbs up
I can't go back, i won't go go back!
Old May 2, 2001 | 01:59 PM
99svtlightning's Avatar
Post
I don't know why SVT chooses the platinum plugs, but they work for most of us. Had to be a reason and they don't seem to hurt performance.
99 Lightning, JL Ram Air, Daiblo Chip(JL Programmed)and 90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, . 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
Old May 2, 2001 | 02:06 PM
DJANIMATE's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by MRBBQMAN:
I can't go back, i won't go go back!</font>
I will...
95 Saleen, I think you mixed up the splitfires and "type-r" sticker, the "type-r" sticker is worth about 500 ponies and the splitfires turn your engine into a VTEC.
Adam
Old May 2, 2001 | 02:24 PM
Post
OK ... more science please!!! Still nobody seems to know the answer and yes I looked at the other threads but question is still unanswered.
Maybe I should try splitfires in my Mustang even though at least 20 people have told me to stay away from them if you have a supercharger.
Old May 2, 2001 | 02:35 PM
MRBBQMAN's Avatar
Thumbs up
I put one in my lawnmower and now the high grass goes down "noproblemo"
Old May 2, 2001 | 02:55 PM
Talking
DJANIMATE:
I stand corrected. But I was almost positive that it was the random japanese characters that turned your engine into a V-Tec?
2000 Red Lightning
BedRug
Old May 2, 2001 | 03:45 PM
DJANIMATE's Avatar
Post
95 Saleen, haha - I see those things in the auto parts store and I crack up "Powered by {random Japanese letters}". I think anyone who buys one of those should be taken to the back room and given a good Singapore style whoopin.
MRBBQMAN - Does that lawnmower have a blower on it? what about a chipenfilter?
ATI,
Sorry your serious question turned into 'amateur night at the Apollo' (me included), I run splits on my Lightning and I love them. I think the reason they say not to run them is because they burn real hot and you can actually melt them with the addition of a turbo/supercharger. At least one guy has melted some on his L but I've been checking mine and have had no problems. I've been told if your running real lean like from a chip you could have problems.
Adam
Old May 2, 2001 | 04:09 PM
MRBBQMAN's Avatar
Wink
how lean would you be running with a 100dry system. i have bad hearing, but my a/f gauge and splitfire plugs say i'm ok
Old May 2, 2001 | 05:26 PM
LTNBOLT's Avatar
Cool
MRBBQMAN,
I went back to test the Autolite 103 plug which performed well. I could only hold out a 1,000 miles before a fresh set of Splitfire SF10D's went back in. All was right with the world again, LOL. I even got a $1.00 rebate on each plug after printing the rebate coupon from their web site. Rebates usually take forever but I received a check in less than 3 weeks. I couldn't believe it.
ATIDominator,
If you are not having pinging problems or maybe running nitrous on the lean side then Splits would be the best running plug you could put in a Gen2 L. I don't think the Splits can handle the heat as well as a solid ground electrode and will fail quicker under these conditions. If you are running on the ragged edge and hear ANY detonation then buy a plug with a solid ground electrode with a little luck maybe it won't fail. If you don't fit into this catagory then the Splits will offer you the best daily driving experience with better throttle response.
Later,
Chuck
Black 00
Chuck's Lightning Page
Old May 3, 2001 | 12:31 AM
DJANIMATE's Avatar
Post
ATI,
I think the reason no one answered you is because this topic has been brought up so many times, do a search and you'll find hours of fine reading material.
Adam
Old May 3, 2001 | 12:42 AM
MRBBQMAN's Avatar
Wink
i use splitfires, because of their special patented twin spark design, it's like having a 16 cylinder engine, or something
