question about the various oil separator kits.
Old Jan 2, 2008 | 10:10 PM
trucknut1378's Avatar
Question question about the various oil separator kits.
ok so i will be installing my upgraded intercooler soon. and i dont want it to end up like the old one. i have seen several styles of the oil separator kit....
1. had a clear canaster that caught the oil
2. was a black canaster that sat ontop the valve cover (rpmoutlet.com)
3. the breather filters on either side of the engine.
what would you guys recommend? the clear canister i kinda like b/c i can keep an eye on the oil..but looks kinda bad sitting there....the canister on the valve cover..how would you empty that one? and how often would you need to change or could you clean the air filter version? thanks for the advice in advanced
Old Jan 3, 2008 | 12:00 AM
KwikSilvr's Avatar
screw those things... go for a pcv complete delte... both sides of the motor, and it will completly eliminate any oil from getting inside there... ALSO delete the egr, that will cut off any dirty exhasut soot from getting in there too...
those oil seperators don't work 100% not one of them... the may work a little, but the only way to keep it clean and bone dry is to eliminate the pcv and egr... plus its cheaper...
Old Jan 3, 2008 | 09:27 AM
brahmus's Avatar
The ONLY seperator that seems to work is the L&S but it's expensive and bulky. I have the clear one and just cleaned my intercooler after 40K miles. It was horrible.
As for the PCV delete, it will keep oil out of the blower, but the smell when you kick on the a/c is strong.
Old Jan 3, 2008 | 11:25 AM
LIGHTNINROD's Avatar
I've been using the L&S one for a year or so now after trying 4 or 5 others with poor results. I haven't pulled the supercharger to check for unwanted oil but the throttle body is clean.
Some L&S info.
Dan
Old Jan 3, 2008 | 06:38 PM
180 bucks sound a lil high. nobody else has any opinions? maybe something less than 100 bucks? that works
Old Jan 3, 2008 | 06:55 PM
brahmus's Avatar
It seems the only thing cheaper that works is the PCV delete. I'm sure you could get creative and come up with something though.
Old Jan 3, 2008 | 09:37 PM
Robert Francis's Avatar
You can do a "search" on here and go back to 2001, you will find several other methods guys used for around $25 or less and you can make the best decison for yourself.
But if you don't want to do the "search," I can summarize up most of what others have experienced and noted on here: most of these methods don't seem to work for all (and I'm not sure why one guy will say method "A" for example, works, and another guy would say it was useless) and some methods don't seem to work for almost anybody. And there are a few guys whose L didn't seem to pass excessive oil at all - and I don't know why they don't.
To summarize the methods that guys report seemingly most successfully in trapping excessive oil vapors in the past couple of years: the L & S seperator from Vince and some of the catch cans. I'm not endorsing either method - just noting what people have said in the past couple of years.
Personally I deleted the whole PCV system years ago and run breathers - but there are some liabilities when doing this too.
Old Jan 4, 2008 | 02:21 PM
brahmus's Avatar
If you search on here you will probably find a picture of the underside of the valve cover. The baffling isn't all that great and adding/modifying it may help reduce the vapors pulled up.
Old Jan 5, 2008 | 09:50 PM
i think i remember reading that some people were using an 03 cobra r PCV valve...does that work?
Old Jan 6, 2008 | 10:05 AM
brahmus's Avatar
For some, but not many.
Old Jan 6, 2008 | 12:00 PM
RidiculousRed's Avatar
Does anyone have a write up on the deleting of the PCV and everything that goes on with it thanks
Old Jan 6, 2008 | 02:05 PM
Stl01SVT's Avatar
It didn't on mine. That was called the dime mod. A dime was also stuffed in the upper vaccuum hose.
Old Jan 6, 2008 | 06:12 PM
stl01svt what did you end up using? and is it working?
Old Jan 6, 2008 | 06:22 PM
Stl01SVT's Avatar
I'm running the L&S oil seperator, and yes it does work. I got lucky and found one used/never installed for $100.
Old Jan 7, 2008 | 11:27 AM
Originally Posted by Robert Francis
personally I deleted the whole PCV system years ago and run breathers - but there are some liabilities when doing this too.
how are the breathers working out for you? what are the liabilities? what all did you need to go this route?
