First fluid change
Old Mar 26, 2001 | 01:26 PM
Rzk's Avatar
Rzk
Post First fluid change
I am considering changing my transmission fluid with my first oil change. I would like to go all synthetic. I am going with Redline for the engine. Is Mercon ATF synthetic? Anyone try using redline ATF?
Old Mar 26, 2001 | 01:40 PM
bggroth's Avatar
Post
Do a search. I was thinking I read somewhere that some guys were having problems with synthetic oil in the transmission. Check into it before switching just to be safe.
Brian
99 red lightning, bassani complete system #1610 of 4000
2000 Lightning, PSP filter/chip, svo throttle body, Bassani, 4.10's
2000 super duty v10
Arctic cat 400 4x4
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
My vehicles http://www.zing.com/album/?id=4293160925
Old Mar 26, 2001 | 02:01 PM
Rzk's Avatar
Rzk
Post
I did look into it. Unfortunately, there seems to be a mixed bag of info, good and bad. There was an arguement of synthetic being good and bad. There was even a disagreement between whether Mercon or Mercon V being inside the transmission. I need clarification badly.
Old Mar 26, 2001 | 05:26 PM
bggroth's Avatar
Post
Rzk,
Sorry I can't be more help, maybe I read it on nloc.org or svtperformance.com. I know I saw it where somebody had the oil smell like the transmission had been slipping and they thought it was caused by synthetic oil. Maybe you should try putting out a post to Fordtech on this board. He works in the Ford transmission factory and seems to be know alot about them.
2000 super duty v10
Arctic cat 400 4x4
Moderator
Old Mar 26, 2001 | 07:04 PM
Rzk's Avatar
Rzk
Post
Thanks much. I might give Fordtech a try. BTW, you have a beautiful Cobra R. I know it is like comparing apples to oranges, but how does it drive compared to your 01 Lightning? I have a 01 Black Lightning myself.
Old Mar 26, 2001 | 07:13 PM
bggroth's Avatar
Post
The Cobra is fun to drive, but not if it is to long of a trip. If you just go out cruising it is a blast. It has complete different manners than the L.
I see you are from Chicago. Have you heard about the Byron meet we are having down there April 8th.? I just picked up a black 01 last week and will be comming down with it. If interested go here: http://www.svtperformance.com/upcoming.htm and check it out. It will be a blast. If you have any questions post here or go into the Cobra R forum on svtperformance.com and post there. I am the moderator of that forum under the name Cobra-R.
Brian
2000 super duty v10
Arctic cat 400 4x4
Moderator
