NEW JL DIABLO CHIP RESULTS!
i just got back from cecil testing the 1st JL DIABLO! chip here's the results!
temp was 53* hum-64 bar-31.1
1-60'-1.69 1/8-7.7 mph-88.9 1/4-12.15 @ 111.2
2- 1.73 7.7 89.1 12.14 111.9
3- 1.69 7.7 89.2 12.12 111.8
I am very excited about the results because i KNOW we will be able to do more! i should have ALL my programs in a few weeks! There working with me 100% JL
93 cobra 10.90@127.00
99 lightning (black)
E.T. 12.07
best mph 112
60 ft. 1.65
(All Throttle No Bottle!)
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
(KEEP IT BETWEEN THE LINES!)
_ _ _ _ _ _ _ _ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:JohnnylightningPerf.com
svtperformance.com
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
Great job johnny.I think you need to take a stock truck to perform some test so you can have a baseline to see if your chip will be as powerful as your old superchip program.Not everybody can afford or wants everything you have to offer so please let me know when you get your same old programs that will work with the average lightning. Im waiting for the release but would like a reasurance that Im gonna get the same
performance as your ol superchip!!!!
Just a patient L owner who is willing to wait for the best!
LQ: i fully understand your statement, i do have many! stock lightning's just waiting to test the new programs! and i plan on doing just that!
JL
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
JL------------------
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
Hey Johnny,
Sign me up as the 2001 test truck. All sounds great! Can't wait for final product and new toys.
Best of luck.
Bill
2001 Black Lightning
Born 01/09/01
Brought home 02/08/01
A.R.E. LS II W/wing
Bedrug
More to come
spark-doctor@mediaone.net
Best of luck.
Bill
Born 01/09/01
A.R.E. LS II W/wing
Bedrug
More to come
Good times for the first time out. You're actually close to your old times,but I noticed your 60 ft's were up. I know you'll get it worked out. Don't forget if you need my help on testing I'll be heading to the track this weekend,and I'd be glad to help. Let's go get those 11's now !!!!!
00 White Lightning
JL (2)Superchip
JL Air Filter
JL Driveshaft Loop
JDM Lower Blower Pulley
2001 90 mm Mass Air
2" Lowering Shackles
Custom built and designed single 3.5 exhaust with Flowmaster Race Muffler
93 Ford Ranger
FI 302 with 185 AFR heads
GT-40 intake w/ported lower
65 mm TB
66 lb injectors controlled by Western Motorsports SDS fuel injection
TDC Stage 2 twin turbos
AOD trans w/Lentch strip valvebody
10 inch convertor and single input shaft
8.8 rearend w/mosier 31 spline axles and 3.08 gears
Chassis Tech Ladder bar suspension
and plenty more !!
00 White Lightning
JL (2)Superchip
JL Air Filter
JL Driveshaft Loop
2001 90 mm Mass Air
93 Ford Ranger
65 mm TB
and plenty more !!
JohnnyLightning,
Those are truly great times. Now please don't take this the wrong way as I am not try to discredit your current times, or your best time in your sig, but would you disclose all mods you are running on your Lightning? As I look at your sig, it does not appear that you have done that. Obviously the 60 ft times reflect some kind of slick or drag radial to work in conjuction with the converter and on the post that you showed pics of you power cooler it was clear that you are not running the stock throttle body. Also, are you running stock gearing? Again, not trying to put any kind of negativity on you, your products or your truck--but just wanting to know all mods to pursue to get some real great track times like yours.
Also, do you have any track times that represent runs made without have the power cooler with ice, and then track times with the ice. I'm just curious how much ET drop can be contributed to that? I would imagine your power cooler would drop an ET pretty significantly.
Best of luck to you in your new business adventure. Sorry things did work out in your earlier venture.
[This message has been edited by Peter B (edited 03-24-2001).]
thanx guys! i could use a 2001 lightning in the miami area..give me a call if interested! JL
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
Here's all that i have done to my truck,
1-JL stage2 ramair kit with Diablosport chip
2-JL powercooler
3-level 10 shift kit
4-svo throttle body
5- 90mm 2001 meter
6-electric fan
7-allumnium driveshaft
8-1.5# upper blower pulley
9-magnaflow muffler
10-pro-torque test converter
11-E.T. streets
i still have the STOCK Gears! and STOCK exhaust!except for the magnaflow(i needed a little more Growel!)
Engine has never been apart ever,still like it was when i bought it. i'm not claiming to have the FASTEST lightning around just 1 of the FASTEST
JL
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
2-JL powercooler
4-svo throttle body
5- 90mm 2001 meter
6-electric fan
9-magnaflow muffler
11-E.T. streets
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
JL,
What about that secret Bars Leaks in your intercooler? Good for .2? lol
Hope your home tomorrow - I'm gonna give you a call.
Black '00
#1,757 built 3/30/00
Clear corners
JDM street program
JDM 2# blower pulley (ordered)
J.L. Stage II ram-air
FRPP Oval throttle body
90mm MAF
MagnaFlow Exhaust
Black '00
Clear corners
JDM street program
90mm MAF
MagnaFlow Exhaust
thanx guys: there's no doubt these awsome trucks have the ability to put down some awsome times with just bolt ons!
yes here shortly we will be offering the 90mm with the diablo chip just please call or e-mail for the details..and i believe the bars leak in the intercooler was worth .3
J/K...JL
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
J/K...JL------------------
E.T. 12.07
best mph 112
60 ft. 1.65
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
svtperformance.com
