Fix for Throttle Body not opening completely?
Old Mar 26, 2001 | 01:47 AM
BfB's Avatar
BfB
Banned For Rules Violations
Post Fix for Throttle Body not opening completely?
After reading this post:
https://www.f150online.com/f150board...ML/010562.html
...I noticed there are some having problems w/ their TB not opening all the way.
...so what is the "fix" for this? I haven't checked mine, but if it is not opening all the way I def. want to rectify this. Any insight would be appreciated!
Thank you,
BfB
Old Mar 26, 2001 | 02:01 AM
alphadoggy's Avatar
Cool
Remove and replace with a Cobra R t.b.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old Mar 26, 2001 | 03:07 AM
gforce's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by alphadoggy:
</font>
Yep, that'll do it. If you want to keep the stock one and it's incorrect, you have to grind or file the plastic bumper where it meets the baseplate with a Dremel tool or something. Do not do this unless you're absolutely sure of what you're doing!!! Not all of you have out-of-whack blade angles!!! I'm sure of it. Just look at the post BABolt put up. Most of you probably have correct angles. I measured mine at several points inside the throttle bores at WOT - off the truck by hand. Mine was goofed.
Black '00
#1,757 built 3/30/00
Clear corners
JDM street program
JDM 2# blower pulley (ordered)
J.L. Stage II ram-air
FRPP Oval throttle body
90mm MAF
MagnaFlow Exhaust
[This message has been edited by gforce (edited 03-26-2001).]
Old Mar 26, 2001 | 07:16 AM
JohnnyLightning's Avatar
Post
yes what jim said... JL
93 cobra 10.90@127.00
99 lightning (black)
E.T. 12.07
best mph 112
60 ft. 1.65
(All Throttle No Bottle!)
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
(KEEP IT BETWEEN THE LINES!)
_ _ _ _ _ _ _ _ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:JohnnylightningPerf.com
svtperformance.com
