got some bosch platinum plus
Old Nov 7, 2007 | 10:56 PM
kromdom's Avatar
GOOD LUCK with your plug change. BTW, SEAFOAM gets my vote!
Old Nov 7, 2007 | 11:01 PM
MGDfan's Avatar
Ha! That's crap too! Naptha and pale oils have no business being poured into any engine, let alone an L.
Old Nov 7, 2007 | 11:13 PM
kromdom's Avatar
yup, this crap has been good for my truck Curious what you use for your Lightning??
Old Nov 7, 2007 | 11:25 PM
MGDfan's Avatar
Don't have one, and it's irrelevant. Just trying to help the youngin' out.
I don't believe in stovepipes; and you should do a search for seafoam posts by a member named Labnerd. It truly is bad stuff.
MGD
Old Nov 8, 2007 | 02:11 AM
kromdom's Avatar
MGD
thanks for the tip, will definitely read up on it.
Old Nov 10, 2007 | 02:03 PM
DirtY_Dave's Avatar
Originally Posted by clonetek
That is correct. You arent supposed to.
I knew i rember someone telling me that! ...! ill stick with my NGKs
Old Nov 10, 2007 | 07:14 PM
litnfast's Avatar
Old Nov 13, 2007 | 10:46 AM
oldfrmtrk's Avatar
If you want to clean out the inside of you’re engine, pour about two gallons of Xylene (paint thinner) 116 octane. Plus add two oz of mystery oil, to a full tank of gas.
You will be amazed at the results!!!
Old Nov 13, 2007 | 12:36 PM
trucknut1378's Avatar
paint thinner? never heard of that one..anyone else have an input on the paint thinner? would that kill the o2 sesors? gaskets?
Old Nov 13, 2007 | 02:47 PM
oldfrmtrk's Avatar
Well have you ever heard of toluene (110) octane, I started with that on my riding lawn mower, then my four-wheeler, push mower and then finally graduated to my truck. It’s a 01 with 90K on the clock, I have been mixing my own fuel after about 5K, for about 6 years now…
I have added too much, and running that high octane, when its cold she is hard to start, and fumbles until she gets warmed up.. However: when it’s hot 95+ that is when it really shines, you can increase boost and not get any pre-ignition!!
I finally explored with adding Xylene, and that worked even better…
My truck is addicted to the stuff; she just loves the heck out of if, anyway do a search, on either Toluene or Xylene, a lot of info out there…..
One bad thing Xylene cost about $6.00 a gal….
Old Nov 18, 2007 | 12:09 PM
shifty_85's Avatar
i had a bad time with Bosch platt plugs. i got about 11,000 miles off them and then they started misfireing all the time under load. then i switched to autolites double platts. but the boschs are made for forigen 4Cyl lower spark plug charge from the coil packs. when you put bosch in a american V-8 the charger from our coil packs/COPs are higher and fry the plugs. when i pulled them out all of them were pure white.
