wire taps? Where do I get them?
Old Mar 13, 2001 | 06:08 PM
John893's Avatar
Post wire taps? Where do I get them?
Does anyone know where I can get some wire taps?
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Mar 13, 2001 | 06:37 PM
curmudgen's Avatar
Cool
Have you ever been in an auto parts store?
Or an electrical supply house?
or a hardware store? and you will need some pliers. and an idea of how big the wire is that you want to tap. (you aren't talking about phones are you. ) Do you know what they look like?
Or if you want to do it the old fashioned way: you need a knife, some wire, and some black tape.
Old Mar 13, 2001 | 06:41 PM
DreaminAboutL's Avatar
Post
Mil-spec grade?
http://terminaltown.com/Pages/page90.html
Old Mar 13, 2001 | 06:43 PM
Nigel Tufnel's Avatar
Post
ask G. Gordon Liddy, he knows all about wire tapping... heh heh...
any decent auto parts store, Radio Shack (a Tandy company), etc.
Old Mar 13, 2001 | 06:44 PM
thepawn's Avatar
Post
Wow, Dreamin, those are cooler then the ones I got from RadioShack.
Daniel
Old Mar 13, 2001 | 07:15 PM
John893's Avatar
Post
I am trying to run RCA cables off of the stock head unit with out cutting any factory wires. I have ordered both the wiring harness that connects to the head unit and the stock wiring harness but wanted to have a back up plan incase these items did not work.
93 Teal Cobra #4656
Old Mar 13, 2001 | 11:00 PM
curmudgen's Avatar
Talking
Normally a wire tap is made to tap into a single conductor. RCA plugs are normally at least 2 conductor and usually with an outer grount sheath and a center conductor inside an insulation sheath. And of course some are just two wires soldered to the outer and inner contacts. You could make a set that would siamese off but they would be not so pretty.
Red 99
Old Mar 13, 2001 | 11:15 PM
John893's Avatar
Post
I am not going to tap an RCA wire into the stock wire. I have line level converts. It is a little box that has inputs for speaker wires coming out of the head unit and coverts them into RCA compatable cables.
93 Teal Cobra #4656
Old Mar 14, 2001 | 01:20 PM
Struck By Lightning's Avatar
Post
FWIW, I would recommend soldering instead of wire taps. A few years installing car stereo/alarms have taught me to avoid them like the palgue. I've seen them cut through wires (not just the insulation, but the actual wires itself), corrosions at the contacts, cause intermitten connections, etc.
Francis
'00 Lightning, S/C 5.4
'93 Mustang GT, N/A 5.7
'00 T-Maxx, N/A 0.15
