Help- coolant everywhere!!!
Old Mar 4, 2001 | 01:11 PM
99WhiteBeast's Avatar
Post
I've checked hoses all look good and tight.
Is it possible to blow out a water pump seal?
Bueller......anybody?
Old Mar 4, 2001 | 01:17 PM
RedThunder's Avatar
Post
Yeah, it's possible that the pump seal blew out. is the belt completely soaked?
Are the oil cooler hoses still intact?
Is the valley dry?
Did you wash off motor with water and refill and run it?
Old Mar 4, 2001 | 01:31 PM
Post
RedThunder,
Belt is a little wet but most is underneath the truck on passenger side. There is fluid in the valley. Oil cooler hoses look good. Have not washed it off and re-run it yet- little scared to do any more damage!
Old Mar 4, 2001 | 01:35 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
There was a post a while back where the fan was eating a cooling line. You might check this one...
good luck....
Old Mar 4, 2001 | 03:33 PM
JohnnyLightning's Avatar
Post
I'll go with speedin bob most likely your hose that goes to the intercooler resivour hit the pulley or belt and it cut a nice little slice in the hose. you might ask how do you know? it happened to me when i went to jersey to work on the Fridge!i pulled up to evan smith and anti freese was going all over the place i bet he had 2nd thoughts about me working on the fridge LOL! JL
93 cobra 10.90@127.00
99 lightning (black)
e.t. 12.41 @ 110.8
best mph 110.8
60 ft. 1.73
New Low E.T. 12.37!)
JL superchip
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
SuperChip Dist.!
(KEEP IT BETWEEN THE LINES!)
_ _ _ _ _ _ _ _ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:JohnnylightningPerf.com
svtperformance.com
Old Mar 4, 2001 | 10:07 PM
BlackLight's Avatar
Exclamation
This happened to me and the white L delivered in the same shipment. The block heater plug blew out. It is located on the driver side. It looks like a electric kettle element with a 3-prong cable connection. It is held in by an extremely poorly designed method...
Old Mar 4, 2001 | 10:16 PM
SnowPlow's Avatar
Post
Ditto on what BlackLight said. I have had my block heater replaced 3 times now for leaking. It was leaking the day I picked the truck up brand new. First time I realized there was a problem I was 8 litres low on coolant. I was lucky it never overheated on me. The block heater can leak and YOU WILL NEVER know unless you check the level in your resorvoir. Every time it leaked on me it would only do so while running under load. Stopped or even sitting idling it would not leak.
99 Lightning in Pull me over Red.
- Build...#1869, June 2nd 1999. 1 of 1533 red
- K&N Filter Charger Kit.
- PSP Chip
- Bridgestone P245/70/R16 Winter Dueler's, on steel rims.
- Best time to date 13.572
Email me at bowerina@aci.on.ca
Old Mar 4, 2001 | 10:24 PM
BlackLight's Avatar
Post
Exactly the same thing. I saw it when going to WOT on the freeway in the middle of nowhere (I was going reaaal slow, officer, honest).
I stopped and it was dripping coolant, but not a stream, only from drops already on the underside. Then I limped to the dealer, and it was dry as long as you stayed below 2500 rpm. Going above 3000 rpm on the hoist, got a trickle of fluid.
Old Mar 5, 2001 | 12:35 AM
Question Help- coolant everywhere!!!
Just jumped on it hard entering the freeway and smoking from behind rear window. Pulled over and coolant is all over under carriage and inside engine on the left side. No apparant hoses burst, intercooler tank full (never leaked before. I limped it home before it overheated- glad I was only a few miles from home!
99 w/24500 miles
No MODS
Old Mar 5, 2001 | 12:38 AM
4D THNDR's Avatar
Exclamation
That's a new one.
Red '00 Lightning,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Old Mar 5, 2001 | 12:54 AM
HANKFAN's Avatar
Post
99 WHITEBEAST- If their was coolant on the ground then you more than likely have a busted hose or a loose hose somewhere.
HANKFAN
Old Mar 5, 2001 | 06:23 PM
Bill Murray's Avatar
Really Old "Member"
Post
Try looking at the heater hose connections toward the back of the intake manifold. There were several posts on this problem a year or so ago. Loose hose clamps I think.
Bill
Old Mar 5, 2001 | 07:13 PM
bggroth's Avatar
Post
According to your posts apparently the Canadians get block heaters in thier trucks? Anybody in the US have a block heater? I am not even aware that it was an option.
Brian
99 red lightning, bassani complete system #1610 of 4000
2000 Lightning, PSP filter/chip, svo throttle body, Bassani, 4.10's
2000 super duty v10
Arctic cat 400 4x4
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
My vehicles http://www.zing.com/album/?id=4293160925
Old Mar 5, 2001 | 08:56 PM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Post
No block heater for me. But I got mine in seatle.
Old Mar 9, 2001 | 11:20 PM
SnowPlow's Avatar
Post
In Canada they all come with block heaters, it's not an option we can even chose to delete. I was up in Sudbury at Christmas and one morning it was around -35 deg C. The L did start even without being plugged in....but she didn't like it very much
- PSP Chip
