18x10 weld rims.
Old Mar 8, 2001 | 01:02 PM
RTKILLA's Avatar
Post
I think so
She has allot of toys on her.
MY BABIES STAT'S
Built 5/4/99
# 917 of 4000
2001 ET: 12.???, we'll find out soon.
When the green light drops, the bullsh*t stops.
MY ZING ALBUM: http://www.zing.com/album/?id=4293132307
Old Mar 8, 2001 | 03:32 PM
Silver-Bolt's Avatar
Post
Nice rims. I am looking at some BBS wheels. 18x10's front and 18x12's rear. About the same money.
2000 Silver Lightning 13.82 (stock)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
Snug-Lid
In the works:
Level 10 converter
4-Link
Old Mar 8, 2001 | 03:37 PM
Neal's Avatar
Cool
HI!... RTKILLA/THEPAWN : I am putting some AMERICAN RACING "LONGBOARD" 18x10 rims om my truck. They have a 6" back spacing. I am going to be running EAGLE FI "SUPERCAR" 315/40ZR-18 tires. The tires measure 12.5 inches sidewall to sidewall and have a tread of 10.5 inches when mounted on a 10 inch rim. I measured and this tire's sidewall will miss the front of the rear leaf springs by about 1 inch. It was the same for the front when the steering wheel is cranked to the left or right. I hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
[This message has been edited by Neal (edited 03-08-2001).]
Old Mar 9, 2001 | 12:05 AM
RTKILLA's Avatar
Post 18x10 weld rims.
http://www.weldracing.com/ProStarXP.html
I thought maybe some of you might like to check these out, thinking about doing a set of 18x10's for the truck.
MY BABIES STAT'S
Built 5/4/99
# 917 of 4000
Old Mar 9, 2001 | 12:53 AM
thepawn's Avatar
Post
Hrm...those are nice...will 315's fit on those okay?
Daniel
Old Mar 9, 2001 | 03:13 AM
weandog#7's Avatar
Post
RTKILLA,
You better measure the wheelhouse good. I was gonna run then on the back but decided that when cornering the tire would flex and may make contact. I saw a support bar for the fender with a bolt that will be close and the brake lines in the back need to be tucked away. These are special order tires so make sure first because they may not take them back. You only have .5" to .75" to work with, I'd hate to baby my baby around corners. Just trying to help
