pump volts
Old Sep 27, 2007 | 10:27 AM
svtsilverback's Avatar
pump volts
okay i have replaced my resistor, relay, filter, fuel line hose while trouble shooting my fuel pressure problem. Now i need to check the volts going to each pump to see if one of them is not working. I am sure i need a volt meter but how/where do i check? thanks
Old Sep 27, 2007 | 04:40 PM
SWThomas's Avatar
Where in the wiring are you going to check for voltage?
Old Sep 27, 2007 | 07:12 PM
not sure. one of my friends is coming over later and he said he knows how/where. i guess as close to the pumps as we can get.
Old Sep 28, 2007 | 08:35 AM
we checked the voltage at the power wires going into the tank. the meter is showing 11.3 volts at this location.
Old Sep 28, 2007 | 02:19 PM
is there a way to test each pump by itself out of the tank?
Old Oct 1, 2007 | 10:35 PM
Ruslow's Avatar
to ck the pump voltage correctly going thru a resistor there has to be a load on it so if you are getting 11.3 volts no load bypass the resistor and see if it still is the same if so there is a problem need to have Battery volts then.You can put the sender in a pail of kerosene and see how the pumps are working.lot less flammable and still give a good idea on the volume and voltages.Stan
Old Oct 3, 2007 | 09:57 PM
roach4047's Avatar
If you're running after market 255 dual Walbro pumps you should bypass the resistor inorder to ensure they're getting a full 12 volts otherwise the pumps will fail prematurely is what I here.
Roach
