Tranny shifting hard
Old Sep 18, 2007 | 06:12 PM
MotoXracing22's Avatar
I've had my Lightning for about two months now and all of a sudden today on my way home from work i was heavy on the gas after a turn-around and it banged 2nd gear like you wouldn't believe(wasn't even WOT). Now it's hitting every gear hard and i don't know why. Any one have this problem?
Old Sep 18, 2007 | 07:11 PM
jec1521's Avatar
Check your MAF and IAC connections. When I installed my CAI, I forgot to plug back in the MAF connection, and it was shifting hard as hell for some reason.
Old Sep 18, 2007 | 07:36 PM
SVTLIGHTING's Avatar
They do shift hard to begin with. Stock...
Old Sep 18, 2007 | 07:56 PM
jec1521's Avatar
Not really.
Old Sep 18, 2007 | 09:14 PM
WigginWilly00's Avatar
Mine does this. It starts out shifting extremely hard to shifting extremely soft at other times. When it does this the OD flashes off and on. It has progressively gotten worse in the past several months.. My third gear has started to slip more and more often. I have checked everything from fluid, to wiring, and even changing to a different tune. Next step is to rebuild the transmission by Circle D in October along with a stall... Good Luck.....
Old Sep 18, 2007 | 09:16 PM
emig5m's Avatar
My 03 brand new was the smoothest running and shifting vehicle I ever driven, lol. And actually, my 04 shifts so smooth you really can't feel it when normal driving... it's sweet!
Old Sep 18, 2007 | 09:24 PM
Mondo1's Avatar
This happens sometimes when a spring in the shifter bore breaks in the valve body. If its only from 1st to second , it very well may be just that.
Old Sep 20, 2007 | 04:00 PM
04LIGHTING's Avatar
MAF CONNECTION X2
Old Sep 20, 2007 | 08:28 PM
Thanks for the replies. I'm gonna check my MAF and IAC tomorrow and i'll let u no. It has seemed to be a little better but right when i think its fixed it will start up on me again like someone else mentioned. So hopefully it's something simple.
