Securing Computer Module After Chip Installation
I just put in a CUX 2 Superchips R9. I taped the chip to the computer module. The plastic clip no longer fits to secure the module to the interior bracket. It does not seem to move around but I am concerned. Any ideas on how to secure the module?? Thanks in advance for the suggestions. By the way, I do not feel any significant power gain, but the WOT shift points and the crispness( read that neck snapping ) of the shifts is great! This is particularly true with respect to the second to third shift. Without the chip, there was a noticeable drop in RPM. With the chip this is eliminated.
The plastic clip does fit. i've done this 20 times. something is wrong, flip the clip over, check to see if the computer is in the bracket properly. you need that clip, otherwise tension can be put on the pins of the harness connection.
The best thing to do is remove the PCM cage and bend the lip flat. Otherwise it will cut the tape eventually and move the chip.
Don't get me wrong. Removing the cage is tough for us ham fisters.
2000 Red Lightning - #835 of 4966 Born 3-8-00 / Delivered 3-22-00
22% Window Tint, Clear Corners, MPulse LoPro Tonneau, AIM 2" Drop Shackles, Bed Rug, PSP Filter Kit, Other Goodies, Group Buy Floor Mats
Best time: 13.45 sec. @ 101.99 mph
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
My Zing.com Album Click Here
[This message has been edited by WHAT04 (edited 03-01-2001).]
I found that the clip can still be installed if I simply move it down, from its previous location, to right below the chip. No modification needed.
Just my .02.
Later,
Jake...
2000 Black Lightning
#54 of 4966
NLOC #476
PSP full meal deal
Level 10 shift kit
SnugLid
BedRug
Wet Okole seat covers
AIM 2" rear drop
13.870 @ 100.52 stock
13.087 @ 104.80 mods
jacobs@revealed.net
Just my .02.
Later,
Jake...
#54 of 4966
NLOC #476
PSP full meal deal
Level 10 shift kit
SnugLid
BedRug
AIM 2" rear drop
jacobs@revealed.net
Yes, bend the lip. It's a biotch getting the bracket out of there so I removed the computer and took pliers and bent the lip straight out, otherwise it will wedge itself between the chip and the computer and do weird stuff. And like he said, just move the clip down below the chip and it will snap into place.
Red '00 Lightning,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Red '00 Lightning,
375 RWHP,
445 RWTQ,
12.974@104.818
Track Videos
Yep, bend the bracket and lower the plastic clip.
2000 Silver Lightning 13.82 (stock)
PSP 4-way
PSP Filter Kit
Snug-Lid
In the works:
PSP Pulley
Level 10 shift kit
Level 10 converter
4-Link
2000 Mercedes ML430 16.01 (stock)
1996 Donzi Z-33 (Twin 502's)81mph
In the works Muzzy ZX12-R 200++ mph 9.94 (stock)
PSP 4-way
PSP Filter Kit
Snug-Lid
In the works:
PSP Pulley
Level 10 shift kit
Level 10 converter
4-Link
I wish I could see a pic of whats going on here so when it comes time to "chip" us new guys can do it like you "vets". :-)
Thanks for the comments. Here is what I ended up doing. I loosened the lower bolt on the bracket. This allowed more space to get the lower part of the plastic clip under the bracket at a spot below the chip area. I then tightened the bolt. Note, the bracket rests on a spongy material to begin with, so when you tighten it back up it there will be more space at the bottom of the bracket than at the top. This is the bottom of the clip pressing the spongy material down.
Guys
These subjects have been covered in detail a couple times
Here is a pic from the "How To" I did last year. In it you can see the Computer module, the black clip and the Blue Superchip. I havent bent the lip and I havent had any trouble yet. The bent clip would be a dead give away to chip install.
More pics here http://www.svtlightnings.com/svt/chip/chip.htm
Doug
Picked up Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !! Best Run 13.25
drbdkb@hotmail.com
My Web Site www.SVTLightnings.com
2000 Lightning, FMS 3.73 gears ( Expensive ), PSP 4 Way Chip, PSP Intake, Valentine 1, Snuglid, Bedrug, Lighted Ford Logos, Superchip R9, and 3m Panther Black nickel tint, Clear corners., Boston Acoustics 5x7s and Components, Alpine v12 5 channel Amp and JL Sub, Chrome SVT Rims and G Force R1a Autocross Tires, .
[This message has been edited by Silver_2000_
! (edited 03-03-2001).]
Doug
drbdkb@hotmail.com
! (edited 03-03-2001).][This message has been edited by Silver_2000_
I removed the bracket that holds the computer into the truck. There are two small bolts that hold it there. I believe that they are 6mm. I put the bracket on the bench grinder and eliminated the lip altogether. It won't interfere with the old or new style chips any more.
Red 00"
Pro-M mass air
Swanson Chip
*******'s bed cover
Red 00"
Pro-M mass air
Swanson Chip
*******'s bed cover
