Spark Plugs
Old Aug 18, 2007 | 11:46 PM
Randal 02's Avatar
Spark Plugs
I'd like to get a set of NGK's one heat range colder than stock, I'm thinking thses are the ones to get. I'd like to know if these would be ok, and what the part numbers would be if anyone knows.
Also, where is the IAC located, and how do you clean it?
Old Aug 19, 2007 | 07:01 PM
Randal 02's Avatar
anybody
Old Aug 19, 2007 | 07:30 PM
SWThomas's Avatar
Get some NGK TR-6's. Those will work fine. The IAC is located on the passenger side of the plenum. Look in the center of this picture. It's the thing with the billet on it.
http://www.chickenears.com/billet_iac_lrg.htm
Just unplug it and remove the two screws that secure it to the plenum. Make sure not to lose the gasket that's between the IAC and the plenum. You can clean it a couple different ways. Some people spray WD-40 into it and then clean it out with Q-Tips. I like to use CRC Electric Parts Cleaner Spray. I just spray it in there, shake it out and let it dry for a few minutes. Then put it back on the same way you took it off and you're good to go.
Old Aug 19, 2007 | 08:47 PM
Randal 02's Avatar
Thank you very much. Are changing these plugs the bitch everyone makes them out to be?
Old Aug 19, 2007 | 09:50 PM
SWThomas's Avatar
If you still have your EGR, yes. If not, no. I do mine in about an hour and that's with taking breaks.
Old Aug 20, 2007 | 09:10 AM
halflife's Avatar
if you have the right tools no, if not yes. I have an EGR and get it done in about 45 minutes now. the snap on long spark plug socket helps and you need a 7 mm, swivel socket to get to some of the coil pac bolts. also some extensions.
Old Aug 20, 2007 | 10:25 AM
KwikSilvr's Avatar
unless you have a whipple, in which case it needs removed to replace blugs.. unless your acrobative..
