Whipple Vacuum at Idle
Old Aug 19, 2007 | 05:12 PM
KwikSilvr's Avatar
What Vaccuum do you guys have after installing the whipple at idle with all the accessories turned off?
Old Aug 19, 2007 | 05:46 PM
promodlightning's Avatar
10 inches of vacume here @ idle.
Old Aug 19, 2007 | 06:10 PM
cklepinger's Avatar
you either have some big *** cams or a major vacuum leak somewhere... or both.. ha...
is that normal you think?
Old Aug 19, 2007 | 06:15 PM
JeffsLightning's Avatar
My guess is big cams for which 10" is normal...
Old Aug 19, 2007 | 08:37 PM
todd abbott's Avatar
Stock block, cams, heads, 22 lbs on my Autometer gauge.
Old Aug 19, 2007 | 10:18 PM
KwikSilvr's Avatar
22lbs?
or 22 in mercury?
Old Aug 19, 2007 | 10:23 PM
KwikSilvr's Avatar
I never got 22" going downhill in gear slowing down from 140MPH...
I got 20" sometimes
when I am running my truck now I am at 15-17".... is this an indication of a leak somewhere possibly?
Old Aug 20, 2007 | 04:47 AM
Ricki F-150's Avatar
I would check to see where your Vac/Boost gauge is connected.
Should be on the lower manifold connection along with your fuel rail sensor line and boost actuator line.
This is below the Whipple mounting flange under the IAC valve.
Old Aug 20, 2007 | 09:54 AM
KwikSilvr's Avatar
yup, same place as my fuel pressure regulator and boost actuator...
speaking of which, the boost actuator should open in vacuum, and close during boost right?
Old Aug 20, 2007 | 10:53 AM
Yes it's important that this opens under vacuum.
Easy to check.
View from the passenger side and operate the throttle by hand.
