Nitrous Express Fire & Ice Pressure Controller Install **PICS & HOW-TO**
Old Aug 16, 2007 | 06:21 PM
SWThomas's Avatar
Cool Nitrous Express Fire & Ice Pressure Controller Install **PICS & HOW-TO**
I finally received my NX Fire & Ice Bottle Pressure Controller today. It's been on backorder with JEGS for a month now. This kit is a pretty straight forward install and seems to be a pretty well put together item. Here's everything that came in the kit...
Here's some close-up's of the heating/cooling unit...
Here's a shot of the pressure transducer. I thought it was pretty interesting that it has an Auto Meter sticker on it...
Old Aug 16, 2007 | 06:22 PM
SWThomas's Avatar
Here's a pics of the control unit...
Now for the install. When you receive the kit you're suppose to set-up the control unit for the bottle pressure you want. You have to remove the (4) screws and the cover of the controller and select the setting you want on the little dial inside. There are settings 1-9. I chose to go with setting 9 because NX system are designed to operate at 1050 PSI and that's what setting 9 is for. The settings are as follows...
0 = 850 PSI
1 = 875 PSI
2 = 900 PSI
3 = 925 PSI
4 = 950 PSI
5 = 970 PSI
6 = 990 PSI
7 = 1010 PSI
8 = 1030 PSI
9 = 1050 PSI
Here's some pics of what this process looks like...
Old Aug 16, 2007 | 06:23 PM
SWThomas's Avatar
I then installed the heating/cooling unit on the bottle. This is done by using the supplied T-Bolt and placing the heating/cooling unit under the rear bottle bracket. The T-Bolt is longer to compensate for the thickness of the heater/cooler under the bracket band...
The instructions say to place the heating/cooling unit on the bottle to where it will have maximum contact. It says not to place it on top of the decal or any other barrier between the unit and the bottle. I placed mine as far back as I could and there was still a little bit of the decal under the unit. Less than an 1/8" though...
Then I installed the pressure transducer at the nozzle of the bottle using an adapter fitting I had previously bought from a nitrous vendor. It comes with an adapter manifold fitting, but it's solid and doesn't swivel. I wanted to point the transducer in a certain direction so I chose to use the swivel adapter. I used a little thread sealer per the instructions and installed it...
Old Aug 16, 2007 | 06:24 PM
SWThomas's Avatar
Next I needed to mount the control unit. It has ears on either side with screw holes in them for mounting, but I didn't want to drill any more holes in my bed. So I used a few pieces of velcro and stuck it to the Bedrug...
Old Aug 16, 2007 | 06:25 PM
SWThomas's Avatar
The next part isn't in the instructions, but it's something I did for convenience. I had previously installed a relay and ran the wires for the heater in preparation of it's arrival. I ran red 12 guage wire from the relay to the weather-pack connector in the picture. I then ran a black 12 gauge wire from the weather-pack connector to a ground on the frame right below the bed. The wiring of the Fire & Ice is very simple. A lot more simple than previous bottle heaters. All you do is hook-up the power and the ground and that's it. Everything is run off the controller. You have to wire in a switch to turn it on of course, but that's simple and in the instructions also. I ran these wires to the other half of the weather-pack connector and connected them. Again, this was for convenience for when I remove the bottle...
Old Aug 16, 2007 | 06:26 PM
SWThomas's Avatar
Then all I had left to do was connect the pressure transducer and the heating/cooling unit to the controller. This was a snap because of the supplied wiring harnesses. I just plugged the harness attached to the controller into the transducer and then used the other harness to connect the controller to the heating/cooling unit...
As you can see on top of the controller there are two ports for wiring harnesses. That is because this one controller can actually operate two separate heating/cooling units. This is great for those guys running dual bottles. The other phone-jack type port is for a remote LED Display that can be purchased separately. It's basically a miniature version of the controller itself and is used to monitor the status of the controller from the cab of the vehicle. I plan to get one very soon...
I must say that this was one of the easiest installs I've ever done. I tested the unit and everything is working just fine. It gets hot pretty quick too. Here's a few more pics of everything installed. I still have to put some black split-loom on the wires, but you get the picture. It also fit's nice under my bottle cover. Some of these pics aren't the greatest because I took them in my garage...
Old Aug 16, 2007 | 06:28 PM
SWThomas's Avatar
BTW, if anyone wants one of these, JEGS is selling them for $100 less than NX is. NX has them for $349 and JEGS has them for $249. I'm not sure if that's a mistake on JEGS' part, but I capitalized on it.
Old Aug 16, 2007 | 06:48 PM
halflife's Avatar
you do great work and are addicted to your lightning!
Old Aug 16, 2007 | 09:03 PM
SWThomas's Avatar
Thanks. Indeed.
Old Aug 16, 2007 | 09:20 PM
Incogneto's Avatar
Looks great!! When are you gonna HIT THAT SHIOT?!?
Old Aug 16, 2007 | 09:43 PM
SWThomas's Avatar
Very soon. I'm gonna get it tuned in a few weeks and hopefully be able to test the system on the track next month. Maybe at L-Fest. I'm still waiting on FJO to release an update for their software to be compatible with Windows Vista. I have the OS on my laptop and I can't use their current software to program my progressive nitrous controller. It would kind of suck to go to the track and find out that the program I have loaded in the controller neats some tweaking and not be able to tweak it.
Old Aug 29, 2007 | 06:51 PM
SWThomas's Avatar
I just wanted to update this How-To with some info about the Remote LED Display that's an option for this kit. This item is used so you can monitor what the Pressure Controller is doing from the cab of the vehicle. It comes with these items...
As you can see the LED Display is basically a miniature version of the controller. And the wire that comes with it is 6 pin telephone wire. The wire proved to be too short for running from the rear of the bed to the cab (by about 4 feet) so I purchased a 25 foot piece from Radio Shack. It was a little too long, but I just coiled up the excess and tie-wrapped it under the dash.
First I covered the wire with black split loom and put some painters tape on the end to protect it during routing.
Old Aug 29, 2007 | 06:52 PM
SWThomas's Avatar
I ran the wire from the controller mounted in the bed down through the hole for the nitrous feed line and the other wires. From there I routed to along the drivers side frame rail following the same path as the nitrous feed line and the wires for the bottle opener and the F&I. I then needed to find a spot to enter the cab and I found one in a rubber grommet just below where my feet go. So I pulled the grommet out and cut a small hole in it to squeeze the wire and loom through for a good seal.
Then I routed it up into the cab and under the carpet. From there I routed it behind the drivers side kick-panel and behind the dash...
Old Aug 29, 2007 | 06:53 PM
SWThomas's Avatar
Then I ran the wire out underneath the steering wheel and coiled the excess and secured it under the dash. I used some velcro to secure the display, but I may go back later and use screws.
That's it. It works like a charm.
Old Aug 29, 2007 | 08:03 PM
Rob_00Lightning's Avatar
WOO HOO niiiiiiiiiiiiiiiiiice job (as usual) Thomas
Got dam you remind me of me (w/me ole 02 "everything was about the Mods")
