JDM Chip and 90mm Install
Old Feb 15, 2001 | 09:49 PM
HIGH ROLLER's Avatar
Thumbs up JDM Chip and 90mm Install
I just installed the new calibrated JDM chip for the new 90mm mass-air,it pulls very hard on the top end and it shifts very aggressively at both shift points.I did notice a little more boost maybe a 1/2 to 1 pound more also.I believe this is the best setup for mass-air chip combo for our L's.
HIGH ROLLER
Old Feb 15, 2001 | 10:31 PM
Hilander's Avatar
Cool
Thanks for the info.
I just got the new JDM street chip two weeks ago.I have the stock mass-air. I believe you had the same chip? As I am thinking of upgrading to the 90mm mass-air I find your comments interesting. Are you saying that you feel it was a worthwhile upgrade over the already very impresive JDM chip with the stock mass? Also what filter are you now using? Thank's for keeping us all informed on your continued L upgrade experiences.
2000 Lightning Silver frost
Clear corners (Front only)
PSP Intake, JDM Chip, Bed Rug, Snuglid
Old Feb 15, 2001 | 11:13 PM
Cool
Hilander,
I would reccommend this upgrade and get your new calibrated chip for it.I have no times to compare yet,but my *** o meter tells me that we will see a higher trap speeds in the 1/4.I am using the JL ram-air kit it bolts on perfectly.Have a good one!
HIGH ROLLER
Old Feb 16, 2001 | 12:26 AM
Spiro99SVT's Avatar
Post
I agree, the ***-O-METER really likes this mod as well also. I look forward to seeing some timeslips real soon.
Spiro-
12.373 @ 110.15
Best 60' 1.76
Tuned by JDM Engineering
4700 lbs.
Old Feb 16, 2001 | 11:36 AM
KidOver40's Avatar
Question
I’ve been watching the board as to which mods will work for me. I would like to do the intake mods with the chip all at once.
This is my thought: JDM Chip, Single blade TB, 90mm MAF sensor, K&N Cone air filter.
Can anyone tell me if I am heading the right direction or do you have a better suggestion?
The truck is driven daily, but I will be taking it to the track to establish some (hopefully respectable) track times.
White '00 #1717
Looking for the best Mods
On Order:
Muth Mirrors
Keyless entry
Looking at hoods!
Old Feb 16, 2001 | 09:54 PM
Cool
Did some testing tonight with my new 90mm mass-air and the new JDM calibrated chip compared to the stock 80mm and chip i gained a consistant 1 full tenth each run and 1 mph over the stock 80mm and chip!I really like this setup and the price is right too!
HIGH ROLLER
Old Feb 17, 2001 | 12:18 AM
Nathan's Avatar
Post
Lemme get this straight ...
You're saying JDM has a chip program that allows you to retrofit a 2001 Mass-air on an older L? And that the 01 MAF just bolts on?
Old Feb 17, 2001 | 12:21 AM
Thumbs up
KidOver40,
I like the mods you have selected,you should be in the 12's club with those mods!
HIGH ROLLER
Old Feb 17, 2001 | 12:24 AM
LSchicago's Avatar
Post
Nathan, the kit includes the rubber elbow that attaches to the TB. They also include the 4" filter adapter required for the 90mm MAF. So yes it does bolt on, you just need a filter with a 4" opening. I'm using a 5" opening on my filter, so I'm having another adapter made for mine. Kidover40, It sounds like you're headed down the same path that I am! Lloyd
2000 Black L #2189. Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth
Old Feb 17, 2001 | 01:42 PM
Spiro99SVT's Avatar
Wink
Wahhh...I need to get to the track. time to lay down some numbers...
Old Feb 17, 2001 | 06:36 PM
collins8's Avatar
Banned
Post
Installed my 90mm MAF and the JDM chip calibrated for it today and I have to agree with HighRroller. A very Strong setup!! I have no data to support that other than the seat of the pants feel.
Rob
Old Feb 17, 2001 | 06:58 PM
Thumbs up
Rob,
Glad to hear you went with there setup,now go get that 2 1/2 inch magnaflow muffler and you will have that growl your looking for!
Rob can you e-mail me! Thanks
HIGH ROLLER
Old Feb 17, 2001 | 07:55 PM
BlkSVTTruck's Avatar
Post
I can't wait to go get this setup done when I go see Jim proir to the big Lightning event.
