fog light removal? help anyone??
Old Aug 3, 2007 | 12:42 PM
03BadAzzLghtn's Avatar
Angry fog light removal? help anyone??
trying to get my fogs off so i can replace the bulb and having a lil' trouble..how do we remove them? is it that one lil' screw in the back the holds everything together?? please help
Old Aug 3, 2007 | 01:08 PM
come on someone has to help before i go freaking crazyyyy
Old Aug 3, 2007 | 01:24 PM
jk007's Avatar
I don't have a lightning but I've got an 03 SCREW. I had to remove my fog lights for my body lift. Out of all the foglights I've ever replaced, they have all worked the same way. Grab the back of the adapter where the light goes into and turn either clockwise or counter clockwise. I never had to unscrew anything. They work just like the headlight bulbs (again, I don't think lightnings would be different but they might be). Anyway, here's a picture of what it will look like once they are out. It was a relatively simple process on my truck. Hope this helps.
Old Aug 3, 2007 | 01:32 PM
crzyforddrvr's Avatar
squeeze the tabs and push the fog light out the front I believe.
Old Aug 3, 2007 | 02:10 PM
nevermind i got it!! thanks for the help anyways
Old Aug 3, 2007 | 02:16 PM
01_White_Light's Avatar
Hopefully, you didn't remove the whole fog light just to change the bulb. All you had to do was unplug the fog light, turn the connector(bulb) a 1/4 turn clockwise and it should pull right out. Also, don't touch the replacement bulb with your bare hands/fingers. If you do it will blow. You need rubber gloves when putting a new bulb in.
Old Aug 3, 2007 | 02:25 PM
no i didn't remove the whole fog light..i did unscrew the screw in the back so i can turn the connector more and remove it..and no i didn't where rubber gloves. I made sure I didn't touch the bulb.
