Front End Noises - The Fix
Old Feb 8, 2001 | 07:35 PM
Lightning/Asp's Avatar
Smile Front End Noises - The Fix
I took the Lightning to a dealer today that has an excellent service department. The front end man was very knowledgeable. I brought the pictures from this chat line of the shifting bolt and washer with me. Sure enough,it had moved. The tech retorqued the bolt. He also put some heavy, longlasting grease on the steering stop to dull the metal to metal contact clunk caused by the metal stud steering stop hitting metal. Problem solved. The whole fix took about six minutes.
Old Feb 9, 2001 | 06:55 AM
SGT A's Avatar
Post
That is not a fix.. Check out all posts by action911... This is the fix.. Welding is not necessary, and re-torques will loosen with time.. Pay a little money for perfection.. Well worth it..
DEVILDOG
Old Feb 9, 2001 | 10:21 AM
blue blood's Avatar
Post
I had mine tightened twice, first time did nothing, second time has worked for over 6 months. I can make those pieces, but I don't feel they are needed (so far).
Tom
Old Feb 10, 2001 | 05:10 PM
Silver-Bolt's Avatar
Post
Installing Herb's washers this weekend. This is the way to go. No weldind and no more movement. replace your nuts at the same time. Do not try and reuse them.
2000 Silver Lightning 13.82 (stock)
PSP 4-way
PSP Filter Kit
Snug-Lid
In the works:
PSP Pulley
Level 10 shift kit
Level 10 converter
4-Link
2000 Mercedes ML430 16.01 (stock)
1996 Donzi Z-33 (Twin 502's)81mph
In the works Muzzy ZX12-R 200++ mph 9.94 (stock)
Old Feb 11, 2001 | 12:34 AM
action 911's Avatar
Post
The Sgt is right!
HJ
