Help on Torque Converter question
Old Feb 9, 2001 | 04:42 PM
coolva's Avatar
Post Help on Torque Converter question
I've having my tranny rebuilt because the Torque converter decided to loose a weight on the bellhousing and chewed the converter up, and they decided to put a slightly higher stall converter in my truck...
She isnt sure the RPM stall, but she said I would noticed the difference, she said it was a has a "K Factor of 145" or 145K Factor, sumthin like that....
Anyone have any idea on what the heck that means when ya convert that to RPMs?
97 Dakota CC, 318, Auto, 4x2
13.50@101.91
Old Feb 9, 2001 | 08:03 PM
alphadoggy's Avatar
Talking
It means that you can kiss your tires goodbye that much sooner.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
Old Feb 9, 2001 | 11:30 PM
coolva's Avatar
Post
I'll take that as no one knows
13.50@101.91
Old Feb 10, 2001 | 12:48 AM
Tiron's Avatar
Post
Okay, I don't have a definate answer for you but I tried to look up some information on the net about it. It seems that the K-factor is a number used when refering to the stall RPM of a torque converter because the actual stall is partially determined by how much torque is applied throught the converter, so a definate RPM is hard to determine. The K-factor is multipled by a constant that seems to be determined by the size of the converter. The only references I found where for GM products and I don't really know how they came up with the constant, but for a 12" convertor in a turbo regal the constat was like 14.25 so estimating off of that would put your stall around ~2000RPM or so with the actual number somewhat dependent on the torque applied.
That is my total knowledge of torque conveters as learned in the past five minutes. If there is someone who actually knows about these things, please feel free to speak up and correct me in any or all of this post.
Hope that helps a little...
Old Feb 10, 2001 | 09:02 AM
coolva's Avatar
Post
I finally got SOME info from someone else as well... here is what they had to say...
<font face="Verdana, Arial" size="2"> The 'K' factor is an engineering term that means the speed of one member
divided by the square root of the torque on the same member." This is
calculated at stall conditions. On a 298 mm torque converter you can
multiply the "K" factor by 14.2574 to get the stall speed. </font>
Basically what you said
I wonder what my stock stall was... &lt;thinking&gt;
Thanks fer yer help bud..
13.50@101.91
