275hp roush f150 beat 2 lightnings?
Old Jan 25, 2001 | 09:21 PM
MACD23's Avatar
Post
i know the rousch mustangs work like this:
stage1: rousch appearence kit (ground effects, wheels, wing, etc)
stage2: stage1 + all the suspension mods
stage3: stage1,2 + supercharger
seems like a waste of money to me. (especially stages 1 and 2)
Old Jan 25, 2001 | 10:33 PM
Twinturbo Ranger's Avatar
Post
Hey guy's you shouldn't let that bother you. I bought my Lightning because FORD built it the way it is. It came from the factory kickn asphalt. Anyone can build a faster truck than this with enough dough,but they won't have the prestiege. Hell I built a Ranger pickup with a twin turbo V8(see sig),but it's not the same as owning the fastest FACTORY PRODUCED truck ever made.You know what I mean????
00 White Lightning,R9 Superchip,Homemade induction with cone type K&N filter,Magnaflow Muffler. 93 Ford Ranger,FI 302 with 185 AFR heads,GT-40 lower intake w/Downs upper,65 mm TB,66 lb injectors controlled by Western Motorsports SDS fuel injection,TDC Stage 2 twin turbos,AOD trans w/Lentch strip valvebody,10 inch convertor and single input shaft,8.8 rearend w/mosier 31 spline axles and 3.73 gears,and plenty more !!
Old Jan 26, 2001 | 06:57 AM
lutwiller's Avatar
Post
Blacklight, I've done all this stuff and I still haven't run in the 1/4. I may wait to run it at the F-150 rally so that I can compare apples to apples (temperature, track conditions).
The truck was purchased as a Sport Package. It had been previously owned and had 3000 miles on it. The original owner paid $36,000 for it, but because the truck was considered used, they were asking 30,000. I got it for 26,000. So with the cost of the mods I have less than 31,000 in the truck. Pretty good deal!
I wasn't looking to have the fastest truck--I bought the wrong vehicle for that. What I have is a head turner that runs good and carries a family. I truly am enjoying my cake!
If I do go to the dragstrip, I will post numbers.
1999 Roush EC flareside, 4x2,Wedgewood Blue, 5.4, 4R100, Vortech Supercharger producing 9psi, 4:10LS, PROM 80mm mass air meter, 30lb injectors, Superchip flipchip, Caltrac traction bars, 6 disc cd changer, Ford bedmat, cowl hood.
