Brake fluid???
Old Jun 9, 2007 | 02:00 PM
SVTLIGHTING's Avatar
Brake fluid???
I just finished my brakes on the 04 and lost all the fluid. Lines, master, caliper wells. I need to fill it and bleed it now. I dont have my manual so I was just wondering what fluid to run. I believe it is DOT 3. Is that correct. Thanks
Old Jun 9, 2007 | 04:19 PM
Falcon11's Avatar
yes, DOT 3
Old Jun 9, 2007 | 06:11 PM
SWThomas's Avatar
I run the Valvoline Synthetic stuff and it works fine.
Old Jun 9, 2007 | 07:29 PM
Dbl G's Avatar
Old Jun 9, 2007 | 07:37 PM
SWThomas's Avatar
Originally Posted by Dbl G
Do those speed bleeders fit the front and the back calipers?
Old Jun 9, 2007 | 07:43 PM
Dbl G's Avatar
Yes they do Sir...
Old Jun 9, 2007 | 07:48 PM
SWThomas's Avatar
Yes they do Sir...
Thanks!
Old Jun 10, 2007 | 02:00 AM
AustinSVT's Avatar
bench bleed that master cylinder
Old Jun 10, 2007 | 02:54 AM
Bench bleed??? You mean gravity bleed them? I dont have 3 days. It will be done today. Thanks guys.
Old Jun 10, 2007 | 07:58 AM
AustinSVT's Avatar
3 days? If you say all the fluid had run dry you will need to do it right.
http://www.superchevy.com/technical/.../0509sc_bench/
